Thread: 04 grand prix heat works periodically
Results 1 to 6 of 6
  1. #1 04 grand prix heat works periodically
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    2004 sc grandprix gtp 85,000 miles
    The thermostat was changed because of a bulging hose at same the time the coolant elbows were changed.
    Now the heat is only warm periodically , it was warm earlier but when getting on the expressway it blew cool. Later on it was warm again. Now its cool again in city driving.
    The system was bleed threw radiator and bleeder screw until the coolant flowed out. The car ran for a good 30 minutes I followed the same procedure I use on all my cars. Should it be bleed again or could the new thermostat be faulty. My heat didn't do this before the thermostat change.
    P.s. My heat was never very hot even before, it has always just been warm compared to other cars I have driven. But that's probably a whole other situation.
  2. #2 Re: 04 grand prix heat works periodically
    Backflush the heatcore.
    To me it seems that is the issue, then do the re-bleeding of the coolant system.
  3. #3 Re: 04 grand prix heat works periodically
    X 2 on flushing the core and bleeding the air out.
  4. #4 Re: 04 grand prix heat works periodically
    Aug 2012
    Chicago
    so Just take off the hoses and spray through the heater core?
  5. #5 Re: 04 grand prix heat works periodically
    Yep that's what you do
  6. #6 Re: 04 grand prix heat works periodically
    Aug 2012
    Chicago
    Will do, thanks.
  1. Replies: 7
    Last Post: 04-24-2013, 11:46 PM
  2. No heat or ac driver side. Blend door actuator works.
    By xekrubx in forum General Tech Discussion
    Last Post: 09-11-2012, 07:50 AM
  3. AC works but getting heat
    By green97 in forum General Tech Discussion
    Last Post: 05-14-2012, 03:04 PM
  4. Grand Prix GTP 2005 TapShift doesnt works..
    By edgt in forum General Tech Discussion
    Last Post: 08-05-2011, 12:39 AM
  5. Get this. I have no heat, heater core works fine.
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2011, 09:15 AM
