Thread: Can rack and pinion cause wobble in steering?
Results 1 to 4 of 4
  1. #1 Can rack and pinion cause wobble in steering?
    SE Level Member teejay's Avatar
    Feb 2013
    ohio
    Front end wobbles slightly on my 02 when I accelerate from a stop up to about 35 mph then its fine. While it is doing this I can hold the wheel at center and move the steering wheel just very slightly back and forth from center and it seems like it kicks a little both ways, like theres a tight spot just off center.Tires are all like new even rotated them no change in steering, struts, tie rods, ball joints,wheel bearings, sway bar bushings all have between 10 and 30,000 miles on them, everything is tight. It steers fine other than that.It feels like a bad tire but I know its not. Could the rack be doing this?
    02,160,000 miles, was silver, painted it black after tornado totaled it,that did'nt take much. American Racing wheels,aluminum grills,Stinger Fiberglass hood,drivetrain stock.
  2. #2 Re: Can rack and pinion cause wobble in steering?
    If the rack is sloppy I could see it causing problems. I have a 1.5 year old rack i'd sell if you're interested.
  3. #3 Re: Can rack and pinion cause wobble in steering?
    Feb 2013
    ohio
    There does'nt seem to be any slop in it at all but I guess that don't mean the rack still is'nt bad? What do you need for the rack and is it new?
  4. #4 Re: Can rack and pinion cause wobble in steering?
    $75 its about a year and a half old.
  1. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  2. Rack and Pinion Help???
    By ill12will8 in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2012, 03:34 PM
  3. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
