"The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid in the evaporative emission control system.
Definition:
EVAP (Evaporative Emission System) purge/vent solenoid circuit condition
Explanation:
The solenoids and system wiring are monitored for opens or shorts
Probable Causes
1- Purge or vent solenoids defective
2- Check connevtor and wiring
3- Fuel saturated vapor canister
4- Failed EVAP vent solenoid
anyone else had to deal with this, any info/help is appreciated."
I copied this from another site and I have the same problem and I have been looking around a while now for the answer. I had this code before and replaced the evap canister twice due to this code and a related one aswell. It has been good for a few months now but it came back.
When I had this code the first time and other people did too we were both able to clear it and it would not come back for a while but not this time.
As soon as I clear the code it comes back on right away! So i am leaning toward a bad wire/connection some where. Any other thoughts or good places I should look for a possible split wire?
Thanks, -John
