Thread: 2000 grand prix p0742 p0336
Results 1 to 3 of 3
  1. #1 2000 grand prix p0742 p0336
    Apr 2013
    wadena mn
    I have 2000 grand prix se . i bought it off a guy cheap he said the tranny needed to be replaced. big deal put one in. It had the symptoms of lugging engine in gear and would barely move. SO i put the used tranny in. It went in reverse i put it in drive and it killed it. kept doing it. Grabbed a scanner found some codes that led me to the common melted wires by the A/C dryer. I repaired the wires and erased the codes. It was running a little rough and shifted hard thru gears. Engine light came on. I pulled codes p0742 tcc stuck on. p0336 crank position sensor ckt A performance. I replaced the crank sensor still same code 336. I checked voltage and ground and monitered green wire at 8 v on 0 v off. SO it should be working. the TCC is stuck on. I took out the fuse to make sure it goes off and yes shifting into drive kills it. so i replaced the fuse and it still shifts hard and gets stuck on. the tranny i put in had 129k on it and has new filter and fluid i added a can of seafoam trans tune to try to unstick the valve. IT seems to get better each time i drive it but still (thumps) into the next gear and high revs sometimes into begining gears. WOULD a relearn fix these problems? I HIGHLY doubt that the tranny is bad or that the tcc should be bad due to low miles. COULD the short in the wires fry that solonoid ? It runs great and sits about 2000rpm at 60 mph. IDK what the normal is. PLEASE help with any ideas. my next step will be a trip to someone who can relearn it. COULD the computer be fried from the short ?
  2. #2 Re: 2000 grand prix p0742 p0336
    Apr 2013
    Hamilton
    check the line pressure coming from the transmission if this is in spec, the best bet would be to just replace the TCC solenoid its not a hard job just pull the tranny pan off and pull a clip and pop it out also while you're in it this far it would be a good idea to re-torque the valve body and replace the filter hope this helps.
  3. #3 Re: 2000 grand prix p0742 p0336
    Apr 2013
    wadena mn
    im wondering if the tranny i took out would work now since i found the wiring issue after. doesnt take to long to switch out maybe worth it ?
  1. Help with p0742 and p0336
    By i hate GPSE in forum General Grand Prix Discussion
    Last Post: 04-11-2013, 05:43 AM
  2. 2000 grand prix p0742
    By i hate GPSE in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
  3. 2000 pontiac grand prix gt sedan bronzemist color 2000 obo
    By wavedout33 in forum For Sale - Vehicles
    Last Post: 02-09-2013, 07:25 AM
  4. 2000 grand prix gt.
    By parkergary5 in forum Introductions/Noob Questions
    Last Post: 02-07-2013, 04:18 PM
  5. 99 Grand Prix GT, P0742
    By joshuaandrew92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-11-2010, 01:09 PM
