Thread: CJ2 HVAC module displaying in Celcius instead of Farenheit
Results 1 to 5 of 5
  1. #1 CJ2 HVAC module displaying in Celcius instead of Farenheit
    GT Level Member japslpr's Avatar
    VA Beach
    THIS ISSUE HAS BEEN CORRECTED....SEE LAST POST FOR CORRECTION.
    I have an issue with the CJ2 displaying the temperature in Celcius instead of Farenheit.
    This occured after I repaired a bad electrical issue with the car. Once I put the entire dash and all the moduels back together and started the car, I noticed the dispay in °C instead of °F.
    Does anyone know how to change this back to °F??
    Please don't say hit the Metric/English button on the DIC cause that does not affect the CJ2 display.
    I have looked for the info on GM's tech site and can't seem to find this info anywhere.
    Thanks!
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  2. #2 Re: CJ2 HVAC module displaying in Celcius instead of Farenheit
    St. Louis
    Do you have the owners manual? Would think it would be in there.
  3. #3 Re: CJ2 HVAC module displaying in Celcius instead of Farenheit
    VA Beach
    Quote Originally Posted by FordMan77 View Post
    I have every Manual known for these cars. But, I found it. It is listed in the wiring diagram for the CJ2.
    There is a 1 wire connector, in the harness to the CJ2 that is broken out away from the main connector. It is about 12" behind the main CJ2 connector. If it is connected, it will read metric. If it is disconnected, it reads imperal.
    All it does is either ground or un-ground that specific wire for switching the unit.
  4. #4 Re: CJ2 HVAC module displaying in Celcius instead of Farenheit
    Good catch and diagnosing.
  5. #5 Re: CJ2 HVAC module displaying in Celcius instead of Farenheit
    VA Beach
    Thanks Bill. You should have seen the electrical repair I just did.
  1. Signature not displaying
    By barnettimpala in forum Forum Bugs/Suggestions
    Last Post: 03-28-2013, 01:32 AM
  2. 2000 GTP HVAC blower module keeps burning out ??!
    By torqueaddict in forum General Tech Discussion
    Last Post: 09-05-2011, 10:28 PM
  3. HVAC Control Module
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2010, 09:55 AM
  4. DIC displaying blinking 0
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2009, 09:28 AM
  5. DIC not displaying after HU install
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 07-20-2009, 03:00 PM
