Thread: Where Should I Hook Into Turn Signal?
Results 1 to 20 of 40
burgundybullet Where Should I Hook Into Turn... 04-08-2013, 03:41 PM
LS1GTP Re: Where Should I Hook Into... 04-08-2013, 06:23 PM
DirtDog Re: Where Should I Hook Into... 04-08-2013, 06:26 PM
rperry435 Re: Where Should I Hook Into... 04-08-2013, 06:36 PM
danielle15 Re: Where Should I Hook Into... 04-08-2013, 06:51 PM
Swiggles Re: Where Should I Hook Into... 04-08-2013, 07:23 PM
BillBoost37 Re: Where Should I Hook Into... 04-09-2013, 07:08 AM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 10:14 AM
DirtDog Re: Where Should I Hook Into... 04-09-2013, 10:20 AM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 10:27 AM
BillBoost37 Re: Where Should I Hook Into... 04-09-2013, 10:28 AM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 10:29 AM
DirtDog Re: Where Should I Hook Into... 04-09-2013, 10:30 AM
BillBoost37 Re: Where Should I Hook Into... 04-09-2013, 10:37 AM
rperry435 Re: Where Should I Hook Into... 04-09-2013, 11:34 AM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 11:45 AM
rperry435 Re: Where Should I Hook Into... 04-09-2013, 04:54 PM
burgundybullet Re: Where Should I Hook Into... 04-10-2013, 10:17 AM
BillBoost37 Re: Where Should I Hook Into... 04-09-2013, 11:38 AM
rperry435 Re: Where Should I Hook Into... 04-09-2013, 04:58 PM
DirtDog Re: Where Should I Hook Into... 04-09-2013, 11:45 AM
BillBoost37 Re: Where Should I Hook Into... 04-09-2013, 11:51 AM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 11:56 AM
BillBoost37 Re: Where Should I Hook Into... 04-09-2013, 12:17 PM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 12:37 PM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 12:34 PM
burgundybullet Re: Where Should I Hook Into... 04-09-2013, 12:46 PM
BillBoost37 Re: Where Should I Hook Into... 04-10-2013, 06:46 AM
rperry435 Re: Where Should I Hook Into... 04-10-2013, 09:37 AM
burgundybullet Re: Where Should I Hook Into... 04-16-2013, 12:19 PM
DirtDog Re: Where Should I Hook Into... 04-16-2013, 12:40 PM
BillBoost37 Re: Where Should I Hook Into... 04-16-2013, 12:27 PM
burgundybullet Re: Where Should I Hook Into... 04-16-2013, 12:33 PM
BillBoost37 Re: Where Should I Hook Into... 04-16-2013, 12:38 PM
burgundybullet Re: Where Should I Hook Into... 04-16-2013, 12:49 PM
DirtDog Re: Where Should I Hook Into... 04-16-2013, 01:20 PM
burgundybullet Re: Where Should I Hook Into... 04-16-2013, 01:25 PM
DirtDog Re: Where Should I Hook Into... 04-16-2013, 01:41 PM
DirtDog Re: Where Should I Hook Into... 04-16-2013, 03:17 PM
burgundybullet Re: Where Should I Hook Into... 06-06-2013, 01:54 PM
  1. #1 Where Should I Hook Into Turn Signal?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    So I am wondering where is the best place to hook wire in extra turn signals for mirrors? Car is a 2000 GP GT. Obviously I would like to have it so the left mirror blinks when left blinker is on and the right when the right is on.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Where Should I Hook Into Turn Signal?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I'm not sure but you should make a write up.
    We'll wait till Bill gets here.
  3. #3 Re: Where Should I Hook Into Turn Signal?
    I live here. DirtDog's Avatar
    Jun 2012
    I spliced into mine right behind the fog light its self. Very easy.
  4. #4 Re: Where Should I Hook Into Turn Signal?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    04-08 has positive output directly out of the bcm for left and right so that's easy as it gets.
    97-03 your best bet is probably at the light housings. Someone else can chime in if they have a better solution
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: Where Should I Hook Into Turn Signal?
    Indiana
    Subd so I can see how it's done when mine get installed!
  6. #6 Re: Where Should I Hook Into Turn Signal?
    Quincy, Mass
    If I remember right Bill hook them into the headlight switch wiring. I plan to tap into them at the gauge cluster harness since I have the wiring schematic in the HUD write up.
    No more GP 04 Impala SS Indy:
  7. #7 Re: Where Should I Hook Into Turn Signal?
    I looked it up in the FSM to find a front directional signal. In the Regal, I think it was located either by the BCM or at the dash to body connector. It's been a while. I also put stock wiring into the factory door connectors. I'm a little retentive when it comes to wiring.
    The less distance and through stuff that you run the better. Tape it up into the factory wiring where possible to keep it clean and protected.
    And..make sure with a test light that you aren't tapping into a rear turn signal. You can test this by pushing on the brake pedal.
    That's right..at first I found it and didn't realize GM used the same wire for both turn and brake.
  8. #8 Re: Where Should I Hook Into Turn Signal?
    Lol. Alight. I figured I would go off of the front ones. However to throw another wrinkle in things do you think that I could get away with hooking up a front facing signal and a rear facing signal up to one side or would that draw too much?
  9. #9 Re: Where Should I Hook Into Turn Signal?
    Jun 2012
    Are u using leds
  10. #10 Re: Where Should I Hook Into Turn Signal?
    Yea. Its like a small 7 led signal I will be putting in the mirror and then an amber 6 led front facing one on the mirror housing.
  11. #11 Re: Where Should I Hook Into Turn Signal?
    Using LED's I wouldn't even bother trying to calculate load etc. They draw so little you could hook up a ton
  12. #12 Re: Where Should I Hook Into Turn Signal?
    Lol. I wouldnt say that if I were you. I will probably end up hooking up a ton now! haha
  13. #13 Re: Where Should I Hook Into Turn Signal?
    Jun 2012
    I have a ton hooked up to my interior lighting and they still draw less than the stock bulbs
  14. #14 Re: Where Should I Hook Into Turn Signal?
    You don't know me well then. I like to make changes which are either subtle and barely noticed or that appear to be standard from the factory. I thought about a fender signal or front mirror housing signal and decided it wouldn't appear factory for a GM vehicle of the period.
    The puddle lights, I would have liked to have done something more involved, yet didn't care to spend the time on them. BTW, while you are running wires and will be in the mirror....if you don't add puddles... you will do yourself a great injustice.
  15. #15 Re: Where Should I Hook Into Turn Signal?
    Oct 2011
    MI
    I'm adding puddle lights to my current build of the turn signals. Thx for the idea lol
  16. #16 Re: Where Should I Hook Into Turn Signal?
    I orginally had puddle lights planned but then a couple weeks ago I installed these logo projectors in the door that shine on the ground and am afraid the puddle lights will be too bright for this.
    Although I could probably just install a rocker switch or something so I could switch between the logo projectors and the puddle lights.
  17. #17 Re: Where Should I Hook Into Turn Signal?
    Oct 2011
    MI
    Quote Originally Posted by burgundybullet View Post
    Awesome dude can u take a few more pics of this different angle? I saw those for sale and couldn't get myself to buy them until I saw them mounted
  18. #18 Re: Where Should I Hook Into Turn Signal?
    Quote Originally Posted by rperry435 View Post
    I put some pictures of them in here to prevent this thread from totally derailing. lol. http://www.grandprixforums.net/burgu...-11-62047.html If this doesnt take you to the right page its the very last one.
  19. #19 Re: Where Should I Hook Into Turn Signal?
    And..I'm unsure of the 04+, but in 2000 GM decided to stop having door lights in the door. If you pull the panel and the reflector is a housing vs a reflector... add the proper socket and bulb.
  20. #20 Re: Where Should I Hook Into Turn Signal?
    Oct 2011
    MI
    I'll either hook them to the outside vehicle illumination circuit (when unlock is pressed at dark reverse and fog lights come on) or a door trigger and timer relay. I'll build my puddle lights into the bottom of the mirror not door.
  1. Turn signal
    By penguinknot in forum General Tech Discussion
    Last Post: 09-11-2011, 04:46 PM
  2. turn signal help
    By sUpErClEaNbLaCkMaChInE in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2011, 08:09 PM
  3. Car dies when using turn signal
    By 4boostin in forum General Tech Discussion
    Last Post: 07-28-2010, 05:57 PM
  4. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
