Thread: Key stuck in ignition, shifter wont move with key on...
Results 1 to 9 of 9
  1. #1 Key stuck in ignition, shifter wont move with key on...
    SE Level Member robstout's Avatar
    cincinnati, oh
    Ok so after searching on here for a while i was unable to find anyone with the same problems. Its an 01 gtp the key wont return to the off position unless i push the manual release, the shifter wont come out of park with key on unless i push the release button, heres the kicker....when i turn the keu to start nothing happens. I have no door chimes or dome lights or dash lights when i turn key on. Battery is good. Sometimes a couple dash lights will flicker real lightly. Ignition switch? Neutral safety switch? Park solenoid? Need help please.....
    Shake-N-Bake!!
  2. #2 Re: Key stuck in ignition, shifter wont move with key on...
    Sounds like an ignition switch. I'm not sure though.. someone else that has needed to diag it should answer soon .
  3. #3 Re: Key stuck in ignition, shifter wont move with key on...
    GTX Level Member blackflag's Avatar
    Virginia
    Rereading, I take it your car wont turn on. What issues did you have when it was running?
  4. #4 Re: Key stuck in ignition, shifter wont move with key on...
    Virginia
    Ignition switch is an easy fix but, I dunno. Is your heater, dic, headlights, heated seat working correctly? security light on? Those are typically the telltale signs of ignition switch failure.
  5. #5 Re: Key stuck in ignition, shifter wont move with key on...
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Definately sounds like an ignition switch
  6. #6 Re: Key stuck in ignition, shifter wont move with key on...
    cincinnati, oh
    No heat no lights ...no nothing. Car ran fine with zero problems an hour before this. Even swapped out the battery for one out of ky tuck just to be sure. Still no change.
    Shake-N-Bake!!
  7. #7 Re: Key stuck in ignition, shifter wont move with key on...
    Virginia
    The fact that you have no power makes it harder. I guess i would go and pick up an ignition switch (about $80) and e4 and e5 sockets. Switch it out, if it doesnt fix the problem return it.
  8. #8 Re: Key stuck in ignition, shifter wont move with key on...
    GTP Level Member
    Nov 2008
    MA
    solonoid in the steering column that communicates with the shift console. it sends a signal to the steering wheel when the the car is in park and ready to release the key
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  9. #9 Re: Key stuck in ignition, shifter wont move with key on...
    SE Level Member 2007's Avatar
    Mar 2013
    bloomingdale, illinois
    is it a pk3 key my friend had a CTS did similar things turned out to be theft control
    87 FORMULA
    07 GXP
  1. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  2. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  3. Key stuck in ignition & shifter wont release!!
    By Pontiac 2003 in forum General Tech Discussion
    Last Post: 04-03-2010, 12:54 PM
  4. NEED HELP ASAP Car wont move
    By gtryda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-11-2010, 03:38 PM
  5. wont move in any gear
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 09:05 PM
