Thread: droppy mufflers
Results 1 to 20 of 24
  1. #1 droppy mufflers
    Apr 2012
    delaware
    I was wondering is there is any way to raise the exhaust system/mufflers so that the tailpipes are closer to the bumper. I recently got a new exhaust system installed (dynomax) and it kinda really bothers me how far down the tips are from the bumper. So is there any way to fix this issue? Thanks for any input.
  2. #2 Re: droppy mufflers
    Did you get new rubber hangers?
  3. #3 Re: droppy mufflers
    If you replace the rubber hanger pieces, that usually corrects the problem.
  4. #4 Re: droppy mufflers
    Have you checked the condition of your exhaust donuts and insulators?
    Edit: ninja'd by bill and fivefingers
    04 Comp G.
  5. #5 Re: droppy mufflers
    I was scalped by Cammer
  6. #6 Re: droppy mufflers
    Apr 2012
    delaware
    the hangers that are on there now are the ones that came with the system. I was going to buy new ones from autozone. Only prob was that when i asked the mechanic that i went to about this problem. He kept saying that "there is no way to fix that issue, its just how the car was made". I kinda walked away thinking that this guy was just being lazy.
    Does it matter what kind of hangers that i buy? cause i was going to just get universal ones from autozone or pepboys and put them on myself.
    Thanks for the responses.
  7. #7 Re: droppy mufflers
    It shouldn't. I've used walkers for replacement and haven't had any issues.
    Edit: make sure they're compatible with your car
    04 Comp G.
  8. #8 Re: droppy mufflers
    Apr 2012
    delaware
    REDCOMPG - Did u replace them for the same issue that i am having?
  9. #9 Re: droppy mufflers
    I was missing one and noticed the passenger side was hanging lower. I just went ahead and replaced them both and since they're pretty cheap it's worth a try
    04 Comp G.
  10. #10 Re: droppy mufflers
    Apr 2012
    delaware
    I really dont wanna be a pain in da ass.....Is there any way that u could take a pic of the rear of ur car? i just wanna see how much it helped before i go any furthur in this. Its cool if dont want to.
  11. #11 Re: droppy mufflers
    Yea sure ill post some in a few hours I'm pretty sure I have some pictures somewhere just gotta find them lol
    04 Comp G.
  12. #12 Re: droppy mufflers
    Apr 2012
    delaware
    Great. Thanks a lot man.
  13. #13 Re: droppy mufflers
    Nov 2011
    NY
    Not to hijack the thred, but rather than start a new one...
    How much flex should there be in the exhaust sys/hangers???
    Reason being I ask is this: I replaced the mufflers with Hooker S/S Max-flows (sound great By the way...) but they hand no hanger bars on them, so I also ordered and used, quite creatively mind you, a few walker hangers.
    http://www.summitracing.com/parts/wlk-36272
    They do have a small piece of rubber separating the clamp from the support bracket, but the overall effect is it is less giving than the stock supports. With the side mounted engine and given movement of it along with the exhaust sys attached to it, will this present any issues?
    Appreciate your thoughts!
    thanks
  14. #14 Re: droppy mufflers
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by coolone View Post
    thanks
    i would think it to be fine, they will be flappin around pretty soon.
    for the price of those hangers you probly coulda found someone to weld hangers on your mufflers. threaded rod is very cheap if you or a friend has a 120v welder
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  15. #15 Re: droppy mufflers
    Nov 2011
    NY
    Quote Originally Posted by Seachicken View Post
    My point is... There's no room for flapping. Lol... Only about 1/2" of travel with that little piece of rubber on the strap.
    $8 for them... Not an overly large expense, but yeah, I could've welded some rod onto the muff's, if the lack of movement causes issues, then I probably will have to.
  16. #16 Re: droppy mufflers
    Apr 2012
    delaware
    How close are ur tailpipes to ur bumper with the hanger change?
  17. #17 Re: droppy mufflers
    Apr 2012
    delaware
    All good bro. I'm interesting in an answer to ur question as well.
  18. #18 Re: droppy mufflers
    What I've had in my phone.. these aren't recent (ignore crocked tips its been fixed since)
    04 Comp G.
  19. #19 Re: droppy mufflers
    Apr 2012
    delaware
    That's exactly how I want them. U remember what hangers u purchased? Thanks again.
  20. #20 Re: droppy mufflers
    It was a Walker from advance..should be the only one that's compatible with the GP when you input your vehicle it was like $4 each IIRC.
    Ill see if I can find you the p/n later
    04 Comp G.
  1. WTF Mufflers?
    By Abrasive in forum Off Topic Discussion
    Last Post: 08-30-2011, 03:18 AM
  2. mufflers
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 11-03-2010, 06:55 PM
  3. mufflers
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2010, 11:01 AM
  4. mufflers
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2009, 12:31 AM
