Thread: Steering Wheel Removal
Results 1 to 9 of 9
  1. #1 Steering Wheel Removal
    Sep 2011
    Southern Alberta, Canada
    Ok I have the air bag out, need way more instructions for that but air bag is out. I bought a Steering wheel puller but is useless cause the wholes I have are not threaded and oval - look at pic - So what has been used for removing steering wheel??????
  2. #2 Re: Steering Wheel Removal
    take that center nut off, then use a medium size 2 gear puller. works like a charm. if it feels like its not coming off with the puller, give it a hit with a hammer on the drive bolt for the puller, it will pop right off.
  3. #3 Re: Steering Wheel Removal
    Sep 2011
    Whats a size 2 gear puller?
  4. #4 Re: Steering Wheel Removal
    Sep 2011
  5. #5 Re: Steering Wheel Removal
    that will work.
    i went to my local HF, bought a steering wheel puller kit, then in the parking lot tried to use it, was like ok this wont work. returned it, and got a 3 piece 2 gear puller set, small, med, and large. for less then the s/w puller lol
  6. #6 Re: Steering Wheel Removal
    Sep 2011
    OK this is the pieces need to at to the steering wheel puller kit, make for these type of steering wheels,Use in conjunction with the 2291 Steering Wheel Puller to remove steering wheels on late model GM vehicles that are not pre-drilled to receive standard bolts.
    Applications Include:
    • Cadillac 1997 and new Catera
    • Chevrolet/GMC 1997 and newer Malibu, Corvette
    • 1998 and newer C- and K-series trucks, full-sized vans, AstrolSafari vans
    • Buick 1997 and newer Park Avenue and Regal Oldsmobile
    • Oldsmobile 1997 and newer Cutlass
    • Pontiac 1988-1993 LeMans 1997 and newer Grand Prix and Trans Sport Van
    Includes bushing to cover the following applications:
    • Ford 1997-Current Explorer, Ranger, Pickups
    • Chrysler 1999 Jeep Grand Cherokee
  7. #7 Re: Steering Wheel Removal
    i bet you still need to give the puller bolt a good shot to pop the wheel off. they are on there tight. and like i said, once real tight, it feels like the wheel will crack, still just hooking it from the sides.
  8. #8 Re: Steering Wheel Removal
    Sep 2011
    OK drilled two holes today, and used the bolts from the puller to thread them (my tap is broken) and then put the puller on and it came off like butter - very little resistance - will post pics.
  9. #9 Re: Steering Wheel Removal
    Sep 2011
    Ok
  1. Steering Wheel - Air Bag Removal
    By 48cj2a in forum General Tech Discussion
    Last Post: 09-07-2011, 06:00 AM
  2. 2002 Mustang power steering pump removal
    By RotyP in forum Off Topic Discussion
    Last Post: 05-25-2011, 12:01 PM
  3. steering wheel lock removal?
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2011, 05:10 PM
  4. Steering Wheel Removal & Installation
    By $03gp/gt$ in forum General Tech Discussion
    Last Post: 12-14-2008, 07:38 PM
  5. Steering Wheel Removal
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-07-2008, 04:46 PM
