Thread: Brake grinding
Results 1 to 3 of 3
  1. #1 Brake grinding
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    When I turn, I can hear my driver side front brake grinding. I can visibly see the wear on the rotor from it. Looking for possible suggestions on what it is. I'm thinking I need to replace the caliper, when I make right turns, my pedal gets very soft until I pump it a couple times. Car is a 98 Gtp with 160K on it
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  2. #2 Re: Brake grinding
    check your pads, sounds like your down to metal. and also check the fluid level in the master, and the rubber hoses to the brake calipers, as they get soft and then fail to hold pressure.
  3. #3 Re: Brake grinding
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    the pads are probably worn down with the indication of that metal piece scrapping the rotor. I'd check the pads first.
  1. 08 GXP Brake grinding only on right turns
    By mrlogic1234 in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2013, 08:19 PM
  2. Brief grinding noise, felt in brake pedal/abs/trac light
    By KZOO3800 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2013, 02:08 AM
  3. a grinding sound
    By chris99gtp in forum General Tech Discussion
    Last Post: 08-24-2012, 08:30 PM
  4. Random brake pedal grinding
    By ptnothere in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2010, 12:25 AM
  5. cam grinding
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:37 PM
