Thread: Aeroforce interceptor
Results 1 to 3 of 3
  1. #1 Aeroforce interceptor
    Apr 2011
    Vassar, Mi
    Just got my aeroforce installed. I bought it used off of here and I never looked at the model number before I installed it. One of the biggest things I was looking forward to using was the annunciator function to warn for KR over 3* but I don't seem to have that function at all. If I go into the menu by holding both buttons down at the same time there is no "setup" or "annunciator" selections available. There is a "shift light" selection but if I click the right button with it highlighted it just goes back to the scan data screen instead of going to the menu to setup the rpm. I have the data speed set to 1 like it says in the instructions too activate the shift light function also. Is there older versions of the aeroforce that don't support the "annunciator" functions?
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  2. #2 Re: Aeroforce interceptor
    Watch this video.
    You have to have this model to do the annunciator function. He shows how to do it I believe.
  3. #3 Re: Aeroforce interceptor
    Apr 2011
    Vassar, Mi
    Yea I don't have any of those functions, mine only has like 3 pages of menu options it just has scan, record, play, read Dtc, clear dtc, shift light, dimmer, invert, input 1 and input 2. No setup, cyclic scan, annunciator, or any of that. Plus if I invert the colors the screen goes out to where its just red and black lines up and down and you cant read any of the data. Gotta love buying used stuff off of here....
  1. Aeroforce Interceptor-where to purchase?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-16-2009, 12:30 AM
