Thread: Coolant sensor
Results 1 to 6 of 6
  1. #1 Coolant sensor
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Okay so when I bought my 01 the low coolant light was on. I did a coolant flush and cleaned the sensor and it was all good. Now 5 months later I did the coolant elbows and when I started my car low coolant light was on. So I filled it up and it stayed on so I pulled it again and cleaned it and it was off. So now the light comes on whenever I start my car but when the thermostat opens the light goes off. Once in awhile it will turn on and off again but not often. Do I just need to clean it really good or do u think I need a new sensor? I'm going to the junk yard tomorrow for some other stuff so should I just pick one up? If I need a new one are there any other cars I can get it off of?
    Thanks
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Coolant sensor
    St. Louis
    If your coolant is truly full then I'd just grab another sensor. Any car with a 3800 should work I would think. So Regal, Monte, Impala, Bonneville etc..
  3. #3 Re: Coolant sensor
    Jun 2012
    Illinois
    sweet thanks
  4. #4 Re: Coolant sensor
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Interesting, I didn't think you could clean it so the light would go off. I just unplugged mine so the light stayed off.
  5. #5 Re: Coolant sensor
    St. Louis
    LS1- yeah, they get gunked up from the Dex and give false readings. I cleaned my original one when the new rad went in and it works just fine, even after 290K.
  6. #6 Re: Coolant sensor
    Jun 2012
    Illinois
    I just went to the junk yard and picked up 2 of em just in case and it works just fine
  1. low coolant level sensor
    By Jgackle in forum General Tech Discussion
    Last Post: 12-31-2012, 01:31 PM
  2. How do I fix coolant sensor?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 11-21-2012, 08:01 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. coolant sensor
    By 1LoudGrandPrix in forum General Tech Discussion
    Last Post: 12-30-2009, 07:56 PM
