Thread: Making a boost activated cutout? Turbo gp
Results 1 to 12 of 12
  1. #1 Making a boost activated cutout? Turbo gp
    Jan 2012
    N/A
    I think they are a sweet idea.
    Have an electric cutout now, Would almost like to make a boost activated cutout.
    What parts would be needed? i can just take the electric motor off the cutout.
  2. #2 Re: Making a boost activated cutout? Turbo gp
    Yoga city
    if your electric you trying get it come open when you hit boost? if so i would just figure out a relay or something of this nature to activate it from a boost signal
  3. #3 Re: Making a boost activated cutout? Turbo gp
    May 2008
    Schuyler, NE
    I'm not sure if these are still available or not. A guy on clubgp used to have one on his turbo GP.
    THMotorsports: Boost Activated Exhaust CUT-OUT .... MORE HORSEPOWER !!! - Cobalt SS Network
    You might be able to make something work with using an m90 BBV.
  4. #4 Re: Making a boost activated cutout? Turbo gp
    May 2012
    Where winter never ends
    Quote Originally Posted by DrSnazzy View Post
    If it were me. I would install the cut out and switch, then splice off switch to a relay controlled by an arduino
    that is getting a boost signal from the car (through the obdii port or output on a body gauge). And basically when the boost signal hits x value flip relay. This would also provide the ability to turn off the feature if need be.
    2000 Regal - Winter Beater
  5. #5 Re: Making a boost activated cutout? Turbo gp
    Jan 1970
    Maquoketa, Iowa
    You could use a hobbs switch with the electric cutout, which there is a delay in opening and you have to stay in boost. Or you could sell the electric cutout and get a boost activated manual cutout and change springs in it to get the desired psi. You could install a switch or a valve in both to arm/disarm them.
  6. #6 Re: Making a boost activated cutout? Turbo gp
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Could wire the switch to a pedal activated one, open at WOT.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  7. #7 Re: Making a boost activated cutout? Turbo gp
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by dbextreme View Post
    This.
    That would make it a true loud pedal.
    GPONA #1 Cyber Bully
  8. #8 Re: Making a boost activated cutout? Turbo gp
    Jan 2012
    N/A
    Hmmm all decant ideas lol.
    The Ebay cutout kit i bought a while back only comes with the keychain remote for opening and closing -_- which i expected a physical switch inside the car .
  9. #9 Re: Making a boost activated cutout? Turbo gp
    May 2012
    Now that would be fun to mess with. The inner geek in me likes that :P Pull remote apart and tap into signal, or clone signal, use arduino to send signal when boost levels hit X or throttle % hits X or really any other condition.
  10. #10 Re: Making a boost activated cutout? Turbo gp
    Ohio
    Fosho has the idea that most all boost activated cutouts use.
    But, hobbs switches fail and it is still a cutout and will still leak like them all.
  11. #11 Re: Making a boost activated cutout? Turbo gp
    Jan 1970
    Maquoketa, Iowa
    The other advantage of a cutout is when its opened, the turbo will spool much quicker, having that electric opening delay/WOT switch or set the boost too high and you will lose that advantage.
  12. #12 Re: Making a boost activated cutout? Turbo gp
    May 2008
    Schuyler, NE
    ^^This.
  1. slight bog under acceleration, only making half boost
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2013, 09:32 PM
  2. What kind of boost are you making??
    By Rudd97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2012, 02:44 PM
  3. bet on s/c making boost 24/7.. input??
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 06:48 AM
  4. not making "full" boost
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2009, 03:23 PM
  5. HELP Not making full boost
    By 1slowhatch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:31 PM
