Thread: Fiero with Series II 3800. Help Needed!
Results 1 to 19 of 19
Threaded View
  1. #1 Fiero with Series II 3800. Help Needed!
    SE Level Member codysGS's Avatar
    Port Perry Ontario
    Hey guys its been a while, long story short i just picked up a 86 Fiero Fastback with a 2003 Impala 3.8L under the hood/deck. Owner says last season it got hard to start at the beginning if each day. It will fire right up with starting fluid or similar spray. Sometimes it starts right up and others it seems to flood out?
    I've yet to drive it but the prior owner says that's the only symptom it had.
    So I cleaned the MAF and the IAC. It fired right up and idled great once I put them in i tried it about 6 hours later and nothing.
    Fuel pressure regulator is new as of today, other was leaking. I tested the pressure. Had over 50psi at prime. But when you flick the key off the pressure drops quickly>>> Only sometimes tho other times it would hold close to 50.
    I have tried unplugging the MAF and starting and it sounds the same.
    I did finally get it started with the MAF removed and a quick spray of carb cleaner than hopped in and cranked her over.
    Please Any ideas, suggestions next steps?
    Also once it fires up it starts easy as pie afterwards. Idle is weird sometimes also
    My rides: 1986 Pontiac Fiero GT fastback 300 SeriesII NA manual
    1999 Buick Regal GS, fenderwell intake, 5 percent tint all round SOLD
    1986 Pontiac Fiero SE 2M6 blown up 3.8na GONE 1989 GMC S15- Derby truck
  1. Turbo 3800 Fiero
    By darkhorizon in forum Track Sessions and Kills
    Last Post: 02-22-2012, 08:30 AM
  2. 3800 s/c fiero swap
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 07-29-2010, 11:40 AM
  3. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  4. Slow Acceleration 3800 Series III in Fiero
    By D2inDFW in forum PCM Tuning
    Last Post: 03-27-2009, 11:37 PM
