Thread: 2005 Grand Prix GTP Issues
Results 1 to 3 of 3
  1. #1 2005 Grand Prix GTP Issues
    Jun 2011
    Ohio
    I have a 2005 Grand Prix GTP with about 98k miles on it. I have been having a couple issues with it. First when it is cold out (even after the car is up to temp) the rpms going down the highway are higher than they should be. I set the cruise at 72 and normally the rpm would be about 2200 then it went to about 2400 and now its at about 2500 - 2600. It feels like the engine is having to work a lot harder to maintain speed. This only happens when it is cold out, things are fine when it is warmer out but it is almost always an issue after a cold night. Next, after riding for a while with the higher rpms, the cruise control will randomly kick off. Sometimes it can be reset right away, sometimes I have to wait a mile. The latest development is that after driving the car, and having the rpm issues the car idles very rough in park (not noticable when stopped in drive), the rpms will jump from arou 900 down to 500 and even inbetween the idle is rough enough to feel the engine shutter. I only notice this if I have had issues with the rmps.I thought it might be the gas, but I ran the tank low and refilled it a couple times at different places (always with premium). I had the rpm/cruise issue last winter and thought it might be the coolant temp sensor, but the mechanic hooked it to the computer and said that is working fine. I have done the following:
    New plugs
    New wires
    New coils
    New MAF
    New brake pedal position sensor
    New brakes
    Oil changed regularly
    Changed super charger oil
    Radiator flush
    I am looking for any suggestions here.
    Thanks
    J.
  2. #2 Re: 2005 Grand Prix GTP Issues
    J,
    You have taken all the fun out of the usual suspects by replacing them. Do you have availability to a real time scanner?
    B
  3. #3 Re: 2005 Grand Prix GTP Issues
    get it scanned at autozone, it may have a code stored, or if the check engine light is already on, take it in to be scanned as the cel holds the key.
    could be a vac leak too.
  1. 2005 Grand Prix GXP FT/FS
    By Jkennedy in forum Wanted To Trade
    Last Post: 12-16-2012, 09:02 PM
  2. Key Fob Issues - 2005 Grand Prix GT
    By Chris Taylor in forum General Grand Prix Discussion
    Last Post: 11-16-2012, 08:51 PM
  3. 2005 grand prix gtp
    By plummer 29 in forum General Grand Prix Discussion
    Last Post: 04-20-2012, 07:15 AM
  4. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
