Thread: EGR fix on SD headers
Results 1 to 17 of 17
  1. #1 EGR fix on SD headers
    The Boss Iceman6669's Avatar
    Jun 2011
    So when I install my SD headers I am going to delete the EGR the proper way. Now I am thinking one of two ways. Way #1 is to weld the EGR port on the headers closed. The other option is to tap it and put a stainless plug in it. I am also going to tap and plug the LIM also when I have it out to do the gaskets.
    2011 F-150 Yote powered
  2. #2 Re: EGR fix on SD headers
    I filled mine with about a 1/2 a tube of copper rtv and pushed a bolt in there
  3. #3 Re: EGR fix on SD headers
    Jun 2011
    Ok. I will prolly tap and plug with a bunch of copper RTV
  4. #4 Re: EGR fix on SD headers
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I have to do this to. Was thinking of getting the blocks from ZZP or Intense (forgot which site had them) but ehh.... Would rather make it look better then that!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: EGR fix on SD headers
    Nov 2011
    NY
    ZZP has them, Miltzy has really snazzy ones... You can make em too!
  6. #6 Re: EGR fix on SD headers
    Oct 2011
    Puyallup WA
    I found some scrap alum and made my own block off plates for LIM and rear header a little rtv and works like a charm! No more annoying tick!
    08 G8 GT - exhaust Tune
  7. #7 Re: EGR fix on SD headers
    Nov 2009
    Tennessee
    Along with the EGR I'm going to delete my rear O2 on my 99 when I put my motor in, in a couple weeks. Does it make it more difficult or easier to tune around having these sensors deleted or is it a moot point?
  8. #8 Re: EGR fix on SD headers
    97-00 cars don't care about the rear o2, only 01+ cars use that rear o2 sensor for fueling.
    Having no EGR will throw 3-4 codes, so those need to be tuned out and some people will lose a mpg or 2, but if you had a tuner and knew where to add timing in the "cruise cells" you can re-gain them back.
  9. #9 Re: EGR fix on SD headers
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    why not just keep it?
  10. #10 Re: EGR fix on SD headers
    You can also keep it..turn it off/on in the tune.
  11. #11 Re: EGR fix on SD headers
    Why don't you just do the standard penny/RTV block off like you should have done in the first place?
  12. #12 Re: EGR fix on SD headers
    Nick..that doesn't cost enough! C'mon man. It's what you do, it's what I do, it's what we suggest to everyone.
    Cheap, easy, done......works for me.
  13. #13 Re: EGR fix on SD headers
    Nov 2009
    Tennessee
    will work for me to!!! Done!!! LOL
  14. #14 Re: EGR fix on SD headers
    Jun 2011
    This way will cost me $0 also and give me a little more piece of mind.
  15. #15 Re: EGR fix on SD headers
    You wanna piece of mind..go talk to your refugee redneck. Likely there's plenty of pieces ...hahaha
  16. #16 Re: EGR fix on SD headers
    Jun 2011
    Lol
  17. #17 Re: EGR fix on SD headers
    Jun 2011
  1. headers.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 03-30-2012, 12:30 PM
  2. Just got my headers
    By zildjian102 in forum General Tech Discussion
    Last Post: 11-24-2010, 09:24 PM
  3. why not headers?
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 05-17-2010, 07:33 PM
  4. headers on a l36?
    By mezzoni in forum Engine
    Last Post: 05-11-2010, 09:59 PM
  5. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
