Thread: 2000 regal gs to 2002 gp gt
Results 1 to 13 of 13
  1. #1 2000 regal gs to 2002 gp gt
    Apr 2012
    Hi i found a 2000 gs motor. Ive been looking for an l67 for a performance rebuild for my car. Would the work with my non-hd tanny? If i got the hd diff conversion from zzp? I also have the regal harness and pcm
  2. #2 Re: 2000 regal gs to 2002 gp gt
    yes the trans will work, but being your car is n/a and your going to put a sc'ed engine in it you will need to have your cars pcm tuned.
    the regal pcm wont work on a gp
  3. #3 Re: 2000 regal gs to 2002 gp gt
    It'll work fine with your non hd trans. You would need a tune though.
  4. #4 Re: 2000 regal gs to 2002 gp gt
    Apr 2012
    Ok thank u very much. I jist wasnt sure. Ya i already have a guy with HP tuner lined up.
  5. #5 Re: 2000 regal gs to 2002 gp gt
    pretty sure you need to hack up the regal harness for the map and injectors.
  6. #6 Re: 2000 regal gs to 2002 gp gt
    Apr 2012
    Oh ok or can i use my gt harness with the extra pieces from zzp( longer map and boost control i think)? What would i have to do to the gs harness if you know that would be great
  7. #7 Re: 2000 regal gs to 2002 gp gt
    ive yet to do it myself, but those parts are needed,(map and evap, and boost solenoid so they need to be wired in. the injectors you can cut and solder them on if need be.
  8. #8 Re: 2000 regal gs to 2002 gp gt
    Apr 2012
    Alright thanks alot scottydoggs you really helped me out
  9. #9 Re: 2000 regal gs to 2002 gp gt
    What hasn't been mentioned is that your flex plate and torque converter won't line up. Two different bolt pattern sizes.
    NA 245
    SC 258
    I would suggest as the easiest thing is to get an L32 (aka new L67) flex that is dual drilled and use that. There is a slight balance difference from L67 to L36. Although.. for the last 8k miles my L26 has been wearing an L67 flex w/o issue
  10. #10 Re: 2000 regal gs to 2002 gp gt
    Apr 2012
    Oh i never thought of that. So the l67 flex plate and tourque converter wont work with the l36 tranny. Im probably just gonna pull a full l67 GTP drive train from the junk yard instead of mixing and matching anh hoping everything works
  11. #11 Re: 2000 regal gs to 2002 gp gt
    as you know your tuner friend will have to tune the trans in as well then.
    also make sure the trans cooler lines match, or take them as well, year to year they dont fit the tranny fittings.
    and the newer trans have a eternal shift deal, where older models have in externally, so you have to swap that if its a newer trans you find. theres a how too, looks pretty simple if you need to do it.
  12. #12 Re: 2000 regal gs to 2002 gp gt
    Apr 2012
    Oh ok. Ya i know im gonna have to find all the differances with all the years. Hopefully i can find one the same year as mine. Ill have to talk to the tuner guy, but i think im gonna go talk to the couple of speed shops here so i know im getting a good tune
  13. #13 Re: 2000 regal gs to 2002 gp gt
    Apr 2012
    Bought a 2000 gtp now from the junk yard for $500
  1. The LIM on my 2000 regal LS goes bad again
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2010, 01:38 PM
  2. 2002 Regal GS motor/trans swapped into a 97 GTP??
    By toast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 11:05 PM
  3. LOOKING for 2000-2002 GTP (2 door only)
    By timmaayy2323 in forum Northeast
    Last Post: 04-06-2009, 08:30 PM
