Thread: Engine / Transmission additives? (More for trans)
Results 1 to 20 of 26
  1. #1 Re: Engine / Transmission additives?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Well the pan didn't look horrible......but all it takes is one little piece of the something that was in the trans cooler to mess with the transmission.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  2. #2 Re: Engine / Transmission additives?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Quote Originally Posted by Greg Badass View Post
    Didn't look horrible. LOL. I think it was bad with all that metal. Especially around the magnet. Some of it came out when I dropped the pan. Fluid was black.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  3. #3 Re: Engine / Transmission additives?
    Apr 2011
    Columbus, OH
    Quote Originally Posted by Silver2kgtp View Post
    I guess I should have typed out a little more of what I was trying to say. Sure it looks horrible but I was talking about how after a rebuilt all of the internals are cleaned thoroughly and put back togther. You'd have to hope that the filter catches most of the crud and crap. Have to figure that even after the rebuild that all the curd and crap stuck in the cooler will be caught by the filter.......like I said, all it takes is one little piece of debris to cause havoc.
    I say give Lucas a try. Worst case you're out $15......but when you're considering the time and effort it's going to take to go through the trans again $15 is a drop in the bucket. Also a shudder is sometimes related to a seal that's going bad......My turbo car has developed a shudder under moderate throtte from a dead stop....I'm gonna be rebuilding soon too.
    Edit: I'm sure if you started a thread about pan drop pics you'll be shocked to see some of the carnage.
  4. #4 Re: Engine / Transmission additives?
    Feb 2008
    NY
    Well the shutter only happened when I'm on the pedal doing a steady speed. The RPMs raise up about 200 during shudder then drop when its over. The shudder happens every 1-2 minutes. That's why I think its the tranny. I'm thinking either a solenoid or converter. Hoping its the solenoid if anything. Don't feel like dropping trans again
  5. #5 Re: Engine / Transmission additives?
    Apr 2011
    Columbus, OH
    I know that you have mentioned crusing speed....what speed are we talking here. I assume that it's happening either while in 3rd and 4th both at speeds where the TCC is commmanded to lock and unlock. Giving a little more infor may help us try and help diagnose the root of the cause.
    And I was just saying mine is going to need a reabuild no matter what......Stock trans w/trans go shift kit only isn't going to last under a cammed turbo car
  6. #6 Re: Engine / Transmission additives?
    Feb 2008
    NY
    It happens almost at any cruising speed. It could be 30 mph or 65. It only happens when I'm on the gas at a steady speed. It does not happen when I let go of gas and the car is just cruising. Doesn't happen when I brake either. I changed almost all the front suspension to rule that out.
    I hear ya with your trans. Lol.
    Btw, I appreciate the help.
  1. Transmission/engine
    By RALM in forum General Grand Prix Discussion
    Last Post: 09-03-2012, 04:50 PM
  2. oil additives discussion
    By apierce1289 in forum Engine
    Last Post: 04-21-2011, 04:31 PM
  3. additives ?
    By 59chevy in forum General Tech Discussion
    Last Post: 08-18-2009, 05:42 PM
  4. Intercooler Fluid Additives?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-23-2008, 10:56 AM
  5. Do oil treatment additives actually stop leaks?
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-08-2008, 02:17 PM
