Thread: Push rods
Results 1 to 15 of 15
  1. #1 Push rods
    Mar 2013
    Sioux Falls, SD
    I'm starting to build another motor for my car. I'm gonna get JE forged pistons, xp hot cam, ported supercharger, ported heads, ported lower intake manifold, ls7 hydraulic lifters, rollermaster double roller, i haven't decided if i want 1.6 or 1.7 high ratio rocker arms. But my question is what size of push rods should i use?
  2. #2 Re: Push rods
    antioch ill
    I dont know if you planned on buying a ported lim and blower but you can do it yourself for free essentially if you have a dremmel tool
  3. #3 Re: Push rods
    I would just use stock pistons. Sorry I don't know enough about pushrods to recommend them.
    04 Comp G.
  4. #4 Re: Push rods
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Depends on the brand rocker arms that you use, as well as if the ported head gets plained at all. When you get all the specs together it should be some simple math to figure it out.
  5. #5 Re: Push rods
    Not really a how to thread here. Moved.
    Your pushrods are going to depend on things like which rockers you use (some aftermarkets have different length) and if your heads are decked much etc etc.
  6. #6 Re: Push rods
    1.6 and 1.7 rollers are a waste of money.
    They also come with new pushrods.
    which will probably be too long seeing as your heads will probably be milled when being ported, and the LS7 lifters like shorter pushrods.
    Another person on here somewhere found 6.95's worked best with an XP and LS7 lifters. YMMV
  7. #7 Re: Push rods
    May 2008
    Schuyler, NE
    How much your heads are milled will depict if you can use stock pushrods or not.
  8. #8 Re: Push rods
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Need to measure lifter preload with an adjustable pushrod to get an accurate measurement. Stock size is 7.050". ls7 lifters like around .030" preload, comp oe-r lifters around .005" i've heard. (I have a set of intense lightweight 7.050" pushrods for sale if that turns out to be what you need) $55 shipped
  9. #9 Re: Push rods
    Pennsylvania
    I thought LS7's were supposed to be a direct swap for our motors.
    There was a thread like a month ago of a cat that put in fresh lifters with stock pushrods making ticking and couldn't figure it out... could that have been his issue?
    Edit: Disregard... he had used lifters and the noise went away after idling for 5 minutes. But still... we can't use stock pushrods with LS7 lifters on a XP/S1X/whatever?
  10. #10 Re: Push rods
    May 2008
    Schuyler, NE
    If you go to the dealer and ask for the part number for a 3800 lifter, it is the same part number as the LS7.
    I've never heard of a difference (size wise) between the two. I will do some measuring on Satruday.
  11. #11 Re: Push rods
    Because the numbers have been superseded numerous times.
    LSx guys seem to end up with .050" larger pushrods after an LS7 lifter swap.
  12. #12 Re: Push rods
    Mar 2013
    Sioux Falls, SD
    Thanks for your inputs! If it helps at all, i'm gonna get higher compression. (9.9:1 and .020 bore over hopefully) so i'll port the heads, i don't think i'll get them milled just because its not highly recommended unless you have warping going on. But if i go with 1.6 rockers, what will i use. Or what have some of you guys used in the past?
  13. #13 Re: Push rods
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    get them milled, im sure at worst theyll remove 8thou
    head gaskets love straight decks, so cheap too
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  14. #14 Re: Push rods
    Mar 2013
    Sioux Falls, SD
    Also, has anyone heard of getting a bigger crank? Lmk!
  15. #15 Re: Push rods
    The Boss Iceman6669's Avatar
    Jun 2011
    I am going to almost promise you won't be able to use stock push rods. Local guy did Xp cam and LS7 lifters and still had to go with smaller pushrods. Now you add in milled heads and I am 99% sure yours will be way to long.
    2011 F-150 Yote powered
  1. push rods/ rocker arm
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-08-2012, 10:21 AM
  2. push rods
    By kenconerly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2012, 07:25 AM
  3. Push rods junk?? and Y??
    By blown383z28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2011, 10:22 PM
