Thread: Aeroforce wont turn on :/
Results 1 to 20 of 27
  1. #1 Aeroforce wont turn on :/
    Jan 2012
    N/A
    Ok so my aeroforce just randomly stopped turning on one day before i put my car away. Starting to get her out and about again and its still not working. Which wire has to go to accessory power ? Because the obdII doesnt supply power correct?
  2. #2 Re: Which aeroforce wire goes to power?
    With the red jumper removed from the back and the 3 wire harness plugged in you need to have the RED wire connected to a 12v power source. I just did it to my radio with a "add a circut".
  3. #3 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    This is what my gauge back looks like. What do you mean
    http://i1207.photobucket.com/albums/...ps9a781c2a.jpg
  4. #4 Re: Which aeroforce wire goes to power?
    Florida
    Make sure the cig. lighter/accessory fuse is good. The OBD2 piggy backs off of that. That's what caused my problem, along with a few other people on here.
  5. #5 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    Ill check this tomorrow. Was going to anyways
  6. #6 Re: Which aeroforce wire goes to power?
    Oh thats a old model aeroforce, I guess I don't know how to make that one work.
  7. #7 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    hmmmmmmmmmmmmm, ill check the fuses over tomorrow, like i said it just randomly did not turn on one day, and would turn on after awhile of having the car started sometimes.
  8. #8 Re: Which aeroforce wire goes to power?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Yup.
    Happened to me.
    The red wire is the power wire (Asked an Aeroforce Tech for clarification).
    Tap into the red wire and send it to a new 12v power source. It turns off because of a poopy 12v power source, so you need to make a new one. Common problem with these old aeroforces.
    I learned that from this user manual which can be found here:
    http://www.aeroforcetech.com/files/I...AL_rev_1_3.pdf
  9. #9 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    Yup.
    Happened to me.
    Really weird. We just found the same thing at the same time lol... Thanks again man!
  10. #10 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    I also just found the manual to my model online, if all else fails ill just move where the power is connected now
  11. #11 Re: Which aeroforce wire goes to power?
    Regal Power!
  12. #12 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    So I hooked the red wire coming out of the obdii connector directly to the radio fuse in the interior fuse panel , still nothing :/ is the obd port fused ?
  13. #13 Re: Which aeroforce wire goes to power?
    You hooked up an DBD2 connector to a radio?
    You are supposed to hook up the red wire from the added harness on the gauge to the radio power on.
  14. #14 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    I have the old aeroforce . Look at the pic I posted , there's a red wire that comes out of the connector like Dan says above ^
  15. #15 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    OK so looking at my interior fuse panel , I found that there's a fuse missing , but there's only 1 fuse post ? Its the 2nd row down 4th from left . You can see there's onlyone post for a fuse to go into wtf? Its ccalled "radio amp 20A " is that linked to the obdii ? The yellow wire I just ran to the red hookup for the aero force .all I had was yellow wire :/
  16. #16 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    Bump for help?
  17. #17 Re: Which aeroforce wire goes to power?
    How about getting a proper add a fuse instead of trying to tuck wires?
    Replace that 20amp radio fuse with the proper 10amp per the cover.
    I've installed a ton of aeroforces. In a GP you need seperate power, it's a GP's suck thing. The better W body doesn't need that power source.
    Turn your cover the same way as your fuse box picture and you will understand that you don't have the optional amplifier in the car. That's why you don't have that other side of the tabs in the fusebox. You aren't missing anything, your car wasn't fully optioned.
  18. #18 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    I know thats just temp. Im trying to figure out why it wont turn on. Isnt making sense to me. Checking all my bases. SO what do you recommend i do. Im not an idiot just frustrated, and stuck.
  19. #19 Re: Which aeroforce wire goes to power?
    You quoted my suggestions. Tucking a wire can result in a poor or lack of a connection.
    Only other thing I can suggest is to test the wire. Once you know it's getting power, have patience. Aeroforces don't come on instanty. They take a moment.
  20. #20 Re: Which aeroforce wire goes to power?
    Jan 2012
    N/A
    I have even hooked it right to the battery, nothing yet :/ Threw a post up on the aeroforce fourms as well. Hopefully i can get some help
  1. Where to run power wire through firewall
    By ahl395 in forum Audio, Security & Visual Electronics
    Last Post: 04-23-2012, 10:01 PM
  2. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  3. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  4. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
