Thread: Loose connections need HELP ASAP
Results 1 to 6 of 6
  1. #1 Loose connections need HELP ASAP
    Jan 2013
    dallas texas
    I have some loose connections after doing the LIM, one sensor connection and two vaccums. I need help identifying.. pictures below. Thank you!!
    ASAP!!!!!
    http://i21.photobucket.com/albums/b2...psac617cae.jpg
    http://i21.photobucket.com/albums/b2...ps4f7d935b.jpg
    http://i21.photobucket.com/albums/b2...pse5123102.jpg
    <a href="http://s21.beta.photobucket.com/user/calikrystal89/media/image_zpsac617cae.jpg.html" target="_blank"><img src="http://i21.photobucket.com/albums/b269/calikrystal89/image_zpsac617cae.jpg" border="0" alt=" photo image_zpsac617cae.jpg"/></a>
    <a href="http://s21.beta.photobucket.com/user/calikrystal89/media/image_zps4f7d935b.jpg.html" target="_blank"><img src="http://i21.photobucket.com/albums/b269/calikrystal89/image_zps4f7d935b.jpg" border="0" alt=" photo image_zps4f7d935b.jpg"/></a>
    <a href="http://s21.beta.photobucket.com/user/calikrystal89/media/image_zpse5123102.jpg.html" target="_blank"><img src="http://i21.photobucket.com/albums/b269/calikrystal89/image_zpse5123102.jpg" border="0" alt=" photo image_zpse5123102.jpg"/></a>
    1998 Regal GS w/ 74,000 mi.
  2. #2 Re: Loose connections need HELP ASAP
    First picture is the HVAC vacuum line that runs along the firewall over the pass side strut tower and then down the firewall into the cabin.
    2nd picture looks like the Temp sensor under the theromstat, but I might be wrong.
    3rd picture is of the back of the Boost solenoid, thats suppose to be open to the air.
  3. #3 Re: Loose connections need HELP ASAP
    look for the vac line down the back of the engine, thats when mine fell to. for pic one.
    pic two does look like it goes to the short harness off the temp sensor under the t stat housing.
    3rd is like five said, its should be open to air.
    and make sure the fat vac line off the top of the TB is not cracked. mine snapped when i did my lim. along with every T and vac line end i took off.
  4. #4 Re: Loose connections need HELP ASAP
    Jan 2013
    dallas texas
    How important is that HVAC? And.. How hard is it to fix?!?!
  5. #5 Re: Loose connections need HELP ASAP
    it controls the air flow in the car. vent to defrost and so on.
    what did you break? the plastic line? if so just break cut it of clean, use a 2 inch piece of vac tubing to splice it back together.
  6. #6 Re: Loose connections need HELP ASAP
    Jan 2013
    dallas texas
    Thanks for quick responses Im working on it now.
  1. Vacuum Line Connections to sensors?
    By GTPGP98 in forum General Tech Discussion
    Last Post: 02-27-2012, 12:58 PM
  2. Electronic Connections
    By Ibwrong in forum General Tech Discussion
    Last Post: 12-17-2009, 06:41 PM
  3. Ideas on How to Clean Coil connections/Spark Plug Wires
    By Panzer4 in forum General Tech Discussion
    Last Post: 10-19-2009, 11:30 PM
  4. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
