Thread: Throttle got stuck wide open
Results 1 to 14 of 14
SilvaMan61 Throttle got stuck wide open 02-27-2013, 09:29 PM
Fivefingerdeathpunch Re: Throttle got stuck wide... 02-27-2013, 09:31 PM
99PontiacGTP Re: Throttle got stuck wide... 02-27-2013, 09:54 PM
BillBoost37 Re: Throttle got stuck wide... 02-28-2013, 06:29 AM
jteske88 Re: Throttle got stuck wide... 02-28-2013, 06:34 AM
SilvaMan61 Re: Throttle got stuck wide... 02-28-2013, 07:25 AM
Gorak Re: Throttle got stuck wide... 02-28-2013, 08:17 AM
SilvaMan61 Re: Throttle got stuck wide... 02-28-2013, 09:08 AM
BillBoost37 Re: Throttle got stuck wide... 02-28-2013, 06:34 AM
BillBoost37 Re: Throttle got stuck wide... 02-28-2013, 08:21 AM
joshv Re: Throttle got stuck wide... 02-28-2013, 09:27 AM
BillBoost37 Re: Throttle got stuck wide... 02-28-2013, 10:54 AM
TLSheff Re: Throttle got stuck wide... 02-28-2013, 11:45 AM
SilvaMan61 Re: Throttle got stuck wide... 02-28-2013, 04:01 PM
  1. #1 Throttle got stuck wide open
    MA
    Prius style.
    I got on the highway tonight after work. It was empty so I floored it, WOT. I backed off after a couple seconds but the throttle stuck wide open. It stayed down for maybe four seconds, hard to tell I was busy ****ting my pants. Anyways I kicked at the pedal and it popped back up.
    Ive never heard of this before on w bodies so I'm fairly sure it was user error. I'm thinking it was the floor mat. It was bunched up under the pedal area. I'm going to replace, or at least clean the TB for a bit of extra insurance. Is there anything else I should do? As you can imagine I don't want this to happen again.
    Im honestly just glad that I was driving, I know my GF wouldn't have reacted the same way.
    SMGPFC Member #9
  2. #2 Re: Throttle got stuck wide open
    Spray some grease or something on the throttle blade spring thing on the outside and make sure your floor mat isnt the problem.
  3. #3 Re: Throttle got stuck wide open
    Sep 2011
    MI
    Quote Originally Posted by SilvaMan61 View Post
    GF probably drives more responsibly, doesn't feel the need to floor it?
  4. #4 Re: Throttle got stuck wide open
    Remove floor mat, push pedal to the floor harshly like you did. Try a few time to get it to stick. If it does..check the cable routing for anything binding it. Then remove the TB and clean it like you never want it to do that again.
  5. #5 Re: Throttle got stuck wide open
    Yoga city
    Tuck n Roll bishes!
  6. #6 Re: Throttle got stuck wide open
    MA
    Quote Originally Posted by 99PontiacGTP View Post
    touche, it's been too long since I've driven like a dumb ass. I can treat myself.
    Will do
    yes sir. For once im glad that I'm slow.
    Quote Originally Posted by JTeske88 View Post
    Tuck n Roll bishes!
    At 90+ I was staying in the car.
    SMGPFC Member #9
  7. #7 Re: Throttle got stuck wide open
    Feb 2013
    Houston
    craziness. happened to me in a 94 Caprice. my friend let me drive it to feel the power vs my then Saturn. he told me to floor it and ya, it got stuck. he said put it in neutral and kill it. it bounced on the rev limiter once and then i stabbed the brakes, and killed the ignition, you gotta maintain the pressure on the brakes, if you let up a little, it wont work cuz the engine is off after you initially applied max press. he explaind all this to me as he was apparently familiar with the problem. 'twas an L88 Caprice with exhaust and under-drives.
  8. #8 Re: Throttle got stuck wide open
    MA
    Quote Originally Posted by Gorak View Post
    same happened to me except mine didn't shut down. My first reaction was brakes and neutral. No avail. Just bounced of the RL a couple times. I tossed it back into drive, probably not the best choice, then managed to break the pedal free.
    Thats might be why my SC belt is bouncing around like a stripper on cocaine.
    SMGPFC Member #9
  9. #9 Re: Throttle got stuck wide open
    He was probably on 128/95. You try and tuck to roll there and a plane might land on ya!
  10. #10 Re: Throttle got stuck wide open
    The brakes still work, they simply aren't power assisted after the vacuum from the engine is used up.
    Grow a leg muscle and you'll stop any car that you want to. Have enough adrenaline in an about to crash situation and you'll have some power in that leg.
  11. #11 Re: Throttle got stuck wide open
    GTP Level Member joshv's Avatar
    canada
    i got my pedal stuck on ny 92 honda 1.5L lol i was worried a bit but not by much as when the pedal was stuck and i was flooring it, an old man passed me in his electric scooter.. but i slaped it in nutral shutr car off, fixed mat and started back up. i went home and cut a big corner out of my mat so i wont have that problem again.
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  12. #12 Re: Throttle got stuck wide open
    Did the mat trick with a 92 Prelude. It's funny, the brakes outperformed the throttle. I slowed the car, bringing the rpm down automatically, then unstuck the mat. Was about to kill engine.
  13. #13 Re: Throttle got stuck wide open
    I live here. TLSheff's Avatar
    Had that happen with a car at work, was in traffic and went to get around a slow car and put the hammer down. I didn't realize the salesman had flipped the floor mat over and it slide up and caught the pedal, at the point I realized what happened, I noticed the truck in front was stopping. Total pants ****ting moment.
    Time slowed, my heart stopped, I bumped the shifter to N, hit the brakes, and kill the ignition. Now stopped about 1 ft away from the bumper, I moved the mat further back, turned the car back on, put back to D and proceeded on. Car was redlined a couple times, bounced off the rev limiter like I was a ricer in a F&F movie, but that's why a limiter is put in place lol.... right?
  14. #14 Re: Throttle got stuck wide open
    MA
    I'm glad that I'm not the only one that has had this happen. I removed the mat and greased the spring. All was well today. Floored it a few times on my way into work. In and out like butter.
    SMGPFC Member #9
  1. wide open throttle technique
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 05:00 PM
  2. Door Signal stuck open on DIC
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2011, 07:39 PM
  3. sunroof visor stuck open
    By hourang in forum General Tech Discussion
    Last Post: 06-30-2010, 04:42 PM
  4. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
