Thread: Throttle got stuck wide open
Results 1 to 14 of 14
Threaded View
  1. #6 Re: Throttle got stuck wide open
    MA
    Quote Originally Posted by 99PontiacGTP View Post
    GF probably drives more responsibly, doesn't feel the need to floor it?
    touche, it's been too long since I've driven like a dumb ass. I can treat myself.
    Spray some grease or something on the throttle blade spring thing on the outside and make sure your floor mat isnt the problem.
    Will do
    Remove floor mat, push pedal to the floor harshly like you did. Try a few time to get it to stick. If it does..check the cable routing for anything binding it. Then remove the TB and clean it like you never want it to do that again.
    yes sir. For once im glad that I'm slow.
    Quote Originally Posted by JTeske88 View Post
    Tuck n Roll bishes!
    At 90+ I was staying in the car.
    SMGPFC Member #9
  1. wide open throttle technique
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 05:00 PM
  2. Door Signal stuck open on DIC
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2011, 07:39 PM
  3. sunroof visor stuck open
    By hourang in forum General Tech Discussion
    Last Post: 06-30-2010, 04:42 PM
  4. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
