Thread: Awful drone when in overdrive.
Results 1 to 6 of 6
  1. #1 Awful drone when in overdrive.
    Dec 2010
    DMV
    Ok need some suggestions. When my car goes into overdrive my mufflers begin to drone and its quite annoying and irritating. So I was thinking of changing the mufflers. Any ideas? I have thrush mufflers on there now but I was told I don't have a resonator. Would a resonator help? Thanks guys.
  2. #2 Re: Awful drone when in overdrive.
    Yes it helps, a res is there to help stop drone.
  3. #3 Re: Awful drone when in overdrive.
    just put a glass pack in there, they cost 25 bucks, new res around a 100. you do the math.
    if you look up a walker res for your car, then look at a glass pack, its the same thing.
  4. #4 Re: Awful drone when in overdrive.
    Dec 2010
    DMV
    Ok cool. Any particular kind I should buy?
  5. #5 Re: Awful drone when in overdrive.
    they are all the same really, you want it to have 2.25 in and out let tubes.
    if you have a fatory pipes you will need to have it welded in.
    if you have after market pipes like i do, you can drop the exhaust and clamp it in, i also bought a flange to the cat and had one tube cut off and the flange welded on to it, so it would bolt up to the cat.
    this is a 32 inch glass pack. my factory res was around 30 inches, (flange to tube end) so after cutting the tube off and adding the flange it fit pretty good.
  6. #6 Re: Awful drone when in overdrive.
    Dec 2010
    DMV
    Ok great thanks guys. I will update when I get it done this week
  1. flowmaster 70s DRONE BAD! :(
    By hondo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 01:24 AM
  2. Just ran at the track. Tell me if I did awesome or awful lol
    By Agentlongwood in forum Track Sessions and Kills
    Last Post: 02-17-2011, 04:10 PM
  3. exhaust drone
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 04:04 PM
  4. Cabin Drone
    By vantage08 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 03:18 PM
  5. Awful morning - I messed up my car :( (please help)
    By yourTVlies in forum Off Topic Discussion
    Last Post: 07-14-2009, 09:01 PM
