Thread: Need advice for new grand prix GTP
Results 1 to 16 of 16
  1. #1 Need advice for new grand prix GTP
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Ive owned 2 GP's so far a 94 SE coupe and my current 03 GP GT Sedan. I love my GT but the thought of having +60 hp with a GTP makes me want to buy one today. My GT just hit 100k and the paint is bubbling on the outside of the rear quarter panel. Tomorrow im test driving a 02 GTP Coupe, 80k leather seats NO RUST in my price range. So what im asking besides the rust around my strut towers and anywhere else what should I be looking for maybe common problems with these? I have no idea what to look for when it comes to the supercharger. Any advice is much appreciated.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Need advice for new grand prix GTP
    Nov 2012
    Madison
    http://www.grandprixforums.net/97-03...ems-60802.html
    check to see if it has headers,possibly modded.... take a pic of the engine if you can and post it if you have time.
    Just drive it and see how it feels, you'll notice the difference...it should feel smooth, beside the torque steer.
  3. #3 Re: Need advice for new grand prix GTP
    Nebraska
    Thanks, ill get a few pics tomorrow to post so I can get everyone opinion.
  4. #4 Re: Need advice for new grand prix GTP
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    It's not worth it lol either way it's slow and it's only good for being a daily driver, I'd just keep the L36 there's less things to break
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  5. #5 Re: Need advice for new grand prix GTP
    Nebraska
    I test drove it today it passed everything on that common problems list. Got it out on the interstate and WOW the power in comparison to my GT was extremely impressive. Even if it is my daily driver and grocery getter means ill still beat those ricers on my way. My first time I got it WOT it did have this odd hesitation but it wasn't exactly a hesitation im familiar with. It quickly corrected itself, you could feel it slam your head back than it hesitated and within a millisecond it was better and i did several WOT tests and it only happened that one time. Any ideas?
  6. #6 Re: Need advice for new grand prix GTP
    Oct 2011
    Michigan
    The lag from the double down shifts probably, did you manually down shift the car yourself?
  7. #7 Re: Need advice for new grand prix GTP
    Nebraska
    No It was in D the entire time.
  8. #8 Re: Need advice for new grand prix GTP
    Oct 2011
    Michigan
    Try manually downshift it and most speeds 2 is your best option just don't try to manually up shift also
  9. #9 Re: Need advice for new grand prix GTP
    Nebraska
    What is that testing? and im not farmilar with double down shifts? im assuming for instance it would go from 3 to 1 ? or 4 to 2?
  10. #10 Re: Need advice for new grand prix GTP
    Oct 2011
    Michigan
    Well if your cruising in a stock GP at say 55mph in 4th gear then you floor it, it'll shift into 3rd then it'll shift into 2nd then it'll go so manually downshifting to 2nd will skip this and give you a better feeling of speed and allow for quicker acceleration
  11. #11 Re: Need advice for new grand prix GTP
    Nebraska
    Oh I understand, Im test driving it again Tuesday ill give it a try but so all gtps have that hesitation when double down shifting?
  12. #12 Re: Need advice for new grand prix GTP
    Oct 2011
    Michigan
    I mean any car in its final drive ratio would even your GT
  13. #13 Re: Need advice for new grand prix GTP
    Nebraska
    How could a person tell if the lim gaskets were changed or not? Its not on the Carfax and it has Green coolant so mabye it had a leak and they decided to put green in? Is green coolant in the oil any different than dex in the oil turning the oil into a milkshake?
  14. #14 Re: Need advice for new grand prix GTP
    Oct 2011
    Michigan
    If they didn't flush the coolant first it's bad they but green it
  15. #15 Re: Need advice for new grand prix GTP
    Nebraska
    But is there any way to know if someone changed the gasket and then put green in it?
  16. #16 Re: Need advice for new grand prix GTP
    If it look at the right between the lim and the head you should be able to if the gasket is aluminum or plastic. Aluminums good. Plastic bad.
    04 Comp G.
  1. Need advice on 1970 grand prix sj
    By carter22 in forum Introductions/Noob Questions
    Last Post: 02-10-2014, 04:43 PM
  2. NOOB about to buy my second Grand Prix, advice welcome
    By KingGlamis in forum Introductions/Noob Questions
    Last Post: 08-18-2012, 06:30 PM
  3. help i need your advice on a 04 pontiac grand prix gt
    By snoop2004 in forum General Tech Discussion
    Last Post: 10-25-2011, 12:08 PM
  4. looking at 04 grand prix gt, advice/tips
    By staycool7989 in forum General Tech Discussion
    Last Post: 04-19-2011, 10:53 PM
  5. Need advice on 1970 grand prix sj
    By carter22 in forum General Tech Discussion
    Last Post: 06-18-2010, 08:42 PM
