Thread: Ignition switch install question. Quick response please!
Results 1 to 3 of 3
Threaded View
  1. #1 Ignition switch install question. Quick response please!
    Jun 2012
    St. Paul, Minnesota
    Well, hopefully this is an easy question to answer. I followed the ignition switch repair guide by sparky to the T and everything went fine up to the reinstall. After installing the new harness and replacing the key and tumbler, the key will not turn counter clockwise from the OFF position nor will it release. I also tried the manual release button, no luck. What might have gone wrong?
    I'd like to leave work sometime soon, hopefully a fast response comes.
    Thanks in advance.
    EDIT: Got it squared away, found another post on here about keys not coming out, solved it.
    Mod can delete this if they please.
  1. NEED RESPONSE QUICK! fuel pump fuse blowing, part throttle hesitation
    By usetaboost in forum General Tech Discussion
    Last Post: 01-02-2013, 08:46 AM
  2. No Throttle response after IC install?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2011, 01:28 PM
  3. Install transponder key ignition switch ?
    By basshead42 in forum General Tech Discussion
    Last Post: 12-11-2010, 11:46 AM
  4. Ignition Switch Replacement Question
    By r1rider in forum General Tech Discussion
    Last Post: 08-21-2010, 03:27 PM
  5. Ignition switch question
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 09:13 AM
