Thread: Radiator Hose Clamp Question
Results 1 to 5 of 5
  1. #1 Radiator Hose Clamp Question
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I am going to be replacing the hoses on my 07 GXP here soon. I was looking at it over the weekend to see what would be involved. Typically, I convert all of the hose clamps to regular old school clamps when I do this. I have always been able to get by taking the old clamps off with regular pliers, but it looks like that might not be the case on the GXP. I have contemplated buying the special hose clamp pliers before just to have in my toolbox as I work on many GM vehicles. I am just trying to determing which ones are the best design to buy.
    I was leaning towards these.
    Performance Tool W80656 - Hose Clamp Plier | O'Reilly Auto Parts
    But I wasn't sure if this design worked well and would fit on the clamps the GXP has given the tight amount of space.
    There are a few other designs as well.
    Wilmar W80655 Angled Hose Clamp Pliers : Amazon.com : Automotive
    Amazon.com: KD Tools (KDT3976) Straight Hose Clamp Pliers: Home Improvement
    Amazon.com: Hose Clamp Pliers Adjustable 90 Degree: Home Improvement
    Has anyone had any experience with any of these particular design and have a preference? At this point I am mostly interested in how they will work on the GXP, but am interested in overall feedback as well.
  2. #2 Re: Radiator Hose Clamp Question
    Personally, I prefer the craftsman ones. They are lifetime and sears is easier to run to for a replacement than any of the links you suggested.
  3. #3 Re: Radiator Hose Clamp Question
    Also..the first link is different than the rest. The first should be what you need. The others are for a single wire type of clamp. I think were mainly used on ford or something.
  4. #4 Re: Radiator Hose Clamp Question
    HUDSON
    Wish I had one of those tools when I did the hoses on my car. I have seen ones with a 2' flexible cable extenstion for getting into the tighter hard to reach areas like the lower radiator hose water pump connection.
  5. #5 Re: Radiator Hose Clamp Question
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    I converted my '04 to old school clamps. It leaks. They need re-tightened every few months. I can't find anything wrong with the clamps honestly. Next flush, I'm putting the old spring clamps back on and not fussing with it again.
  1. Flush/Drain Coolant from Bottom Radiator Hose
    By kennn in forum General Tech Discussion
    Last Post: 07-08-2012, 03:56 PM
  2. ac hose question
    By RyanL in forum General Tech Discussion
    Last Post: 07-07-2011, 09:05 PM
  3. lower radiator hose
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2011, 09:46 PM
  4. radiator hose
    Last Post: 08-17-2009, 11:11 PM
  5. Radiator Hose Diameter
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 05-20-2008, 03:01 PM
