I just got done doing a cam swap and top swap on my 98 GT. Now this is the first motor i have ever built or modded. I was not aware that you were supposed to prime the oil pump system before you start it, so i started it and only ran it for like litterally 5 or 6 seconds then shut it off. Do you think it hurt anything when I did this? And the only reason I ask is because I took the rear vc off and there was no oil in the head, SO i researched and concluded that it is probably because i did not prime the system....thoughts?
