Thread: cooling issues
Results 1 to 20 of 23
  1. #1 cooling issues
    Jun 2012
    About 2 months ago i realized my car was over heating. I noticed my coolant wlow. I added until it was full. A whole gallon later... it was full. Back to normal no over heating.
    Well today i noticed my car was getting hot. Car wouldn't blow out heat when idling only cold air. When.i would accelerate the temp would go down. And the heat would blow again. So added another half a gallon of coolant, and that seemed to fill it. Anyone got any ideas on the problem?
  2. #2 Re: cooling issues
    I live here. DirtDog's Avatar
    Jun 2012
    On the side where the serpentine belt is there's two coolant elbows that are extremely common to crack and or leak check those. Also make sure there's no radiator leaking.
  3. #3 Re: cooling issues
    Probably would help if we knew what you drove. My guess is lower intake manifold gasket leaking or coolant elbows.
  4. #4 Re: cooling issues
    Jun 2012
    Sorry thought i added that 04 gtp. . I checked the lines. Its not leaking anywhere
  5. #5 Re: cooling issues
    Jun 2012
    Quote Originally Posted by Jtg1551 View Post
    Check ur oil...if its sludgie....then its ur LIM
  6. #6 Re: cooling issues
    I'd say your lim gasket is leaking then if you have no noticeable leaking anywhere.
  7. #7 Re: cooling issues
    Jun 2012
    with that much lost though wouldnt he have already thrown a bearing?
  8. #8 Re: cooling issues
    Jun 2012
    No sludge either
  9. #9 Re: cooling issues
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    Im sure its the LIM gasket
  10. #10 Re: cooling issues
    Jun 2012
    Park it somewhere dry and with it running look for drips or leaks.
  11. #11 Re: cooling issues
    Jun 2012
    Notta damn thing
  12. #12 Re: cooling issues
    Jun 2012
    Hmmmm...has there been an antifreeze smell inside of the car?
  13. #13 Re: cooling issues
    Jun 2012
    No. It hasn't show. Any signs of anything until tonight. But i just filled it up again and filled tge resivior and just drove it and it never started to over heat, so i really don't know what to think
  14. #14 Re: cooling issues
    Jun 2012
    Well the first thing is to find where the antifreeze is going...did u actually drain ur oil pan and look at it? Cause there's really only so many places that it can go
  15. #15 Re: cooling issues
    Jun 2012
    I just changed my oil 2 weeks ago.
  16. #16 Re: cooling issues
    Jun 2012
    Was it doing the vanishing antifreeze trick then as well?
  17. #17 Re: cooling issues
    As we said before, its the intake gaskets. Its a super common issue.
    A leaky intake gasket will just eat coolant untill it blows out completely and you get a awesome chocolate milkshake in your crankcase.
    From what I read, you arent seeing a single drop anywhere, so where else can the coolant go beside being burned up in the cylinders.
  18. #18 Re: cooling issues
    SE Level Member SlprGS's Avatar
    Greensboro, NC
    I have the exact same issue with my girl's 2005 NA minus the coolant loss.. I replaced the lower and upper intake plus the elbows. Before then, we had the engine tested with a dye to determine whether or not the heads were bad, but no issues.
  19. #19 Re: cooling issues
    Jun 2012
    Vanishing antifreeze trick? Care to explain?
  20. #20 Re: cooling issues
    what engine do you have? n/a or s/c? if n/a the upper intake fails and the engine eats the coolant. or it leaks into the engine oil and KILLS the engine.
    you have much reading to do grasshopper.
  1. cooling fan issues
    By nakedredneck in forum General Tech Discussion
    Last Post: 12-10-2012, 08:36 PM
  2. Cooling issues?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 04:37 PM
  3. Cooling system issues.
    By Curt7 in forum General Tech Discussion
    Last Post: 08-15-2011, 12:47 PM
  4. Cooling System Issues
    By CSteen85 in forum General Tech Discussion
    Last Post: 07-28-2010, 06:47 AM
  5. Help me with my cooling issues.
    By Rocket468 in forum General Tech Discussion
    Last Post: 07-24-2010, 07:42 AM
