Thread: Do Pace Setters FIT?
Results 1 to 20 of 25
  1. #1 Re: Do Pace Setters FIT?
    I live here. TLSheff's Avatar
    Ok notice the picture above, the very bottom piece to the right. That is the very end piece^^^^, CAT is to be welded there 3" - 3", then tapers down as you can see, and has the flange. At the top by the flange is the 02 bung, you can see it, it will hang out to the side, right by the hangers.
  2. #2 Re: Do Pace Setters FIT?
    So you don't have to go back a page to see what I mean.
    You can get the CAT in and weld the bottom 2 pieces in the picture with the CAT anywhere in the middle. You just have to make sure the length is right, if you weld it too short it won't bolt to the Cat-back exhaust system.
    I say only weld those bottom 2 pieces so you keep the 3 bolt flange for the header adapter, and the 2 bolt flange for the Cat-back exhaust.
    You can also weld the adapter (pictured far right, middle), to the couplers, and the top coupler to the rear header. Just make sure you leave the crossover and use clamps for it, to make it easier to install. Everything else should bolt together.
    Again, just make sure you do the proper measurements before welding. Too short or too long will cause problems.
  1. nasa pace car
    By smitz327 in forum General Grand Prix Discussion
    Last Post: 05-09-2021, 05:51 PM
  2. 1997 Pace Car
    By windowrattler in forum General Tech Discussion
    Last Post: 11-29-2010, 03:11 PM
  3. pace setter dp
    By badbrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 10:05 PM
  4. pace setters
    Last Post: 03-11-2009, 10:56 PM
