Thread: Battery draining
Results 1 to 8 of 8
  1. #1 Battery draining
    Destroys cars izup69's Avatar
    Iowa
    Well the car started off fine a little while ago the battery took a dump. I replaced it with a new battery and have not ran the car verry much since then. The battery held a charge for a good month before it drained. Now The battery is dead every morning. If I jump the car and run it for about 30 min it charges fine. Come out the next day and the battery is dead. Was thinking maby the alt was bad and it was somehow pulling juice from the battery. Even tho the car is off and parked. The alt is less then a year old. Battery is less then 2 months old. At first I thought it might be my amp so I pulled the main fuse. Made no diffrence. I do not have a tester to check If there are any more drain points. I can unplug everything I think of and it still drains the battery. Any ideas ? Would it still be the alt maby ?
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: Battery draining
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    You probably got it fixed by now, but if not, bring it to auto zone where they can check if there is a battery drain somewhere. I had a problem with mine where the trunk light was staying on even while it was closed.
  3. #3 Re: Battery draining
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by izup69 View Post
    Could be a bad battery. Advanced auto can check the alternator as I had mine yesterday checked. If the cars running and u disconnect the battery negative that's a good way to check the alternator as well
  4. #4 Re: Battery draining
    SWPA
    Alternator isn't going to drain the battery when the car isn't running. The alt basically either charges or it does not charge when the car is running. It is not going to drain the battery either way, it just won't charge it.
    You might have a faulty battery. Need to have it tested to make sure the CCA's are up to snuff, and to make sure you don't have a bad cell.
  5. #5 Re: Battery draining
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Wrong.
    An alternator can back drain a battery when it goes bad. Simple test is disconnect alternator overnight an reconnect. If battery holds charge its a bad alternator. We have run into this a few times. Alt checks out fine and charges great yet battery still goes dead.
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  6. #6 Re: Battery draining
    SWPA
    I've never run into that, and have never known anyone to run into it, and I have dealt with a few bad alternators. None have ever killed the battery when the car wasn't running.
  7. #7 Re: Battery draining
    Jun 2012
    Yea I agree more with this statement. My regulator in my alternator is bad right now and it only drains battery when car is running
  8. #8 Re: Battery draining
    Sep 2011
    bedford, Pa
    So did the op figure out what his battery drain issue was?
  1. 2004 Pontiac Grand Prix Battery draining while car is off Please help someone!!!!!
    By postal G in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2013, 05:57 PM
  2. Draining Coolant
    By G8guy in forum General Tech Discussion
    Last Post: 02-07-2012, 04:55 PM
  3. draining coolant
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2011, 09:45 PM
  4. Draining coolant..
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 01:36 AM
  5. 2000 Grand Prix Gt draining battery
    By Kranium31 in forum General Tech Discussion
    Last Post: 01-22-2010, 07:42 PM
