This all started a few days ago during our near zero degree weather. CEL on startup, can clear the subject codes and they wont come back until the next engine start up. Fuel gauge (tank is actually about 1/2 to 3/4 full) all over the place, goes randomly from empty with associated low fuel light, to peggged high full,and then back again. Also getting flickering low washer fluid level light especially on hills and on ramps but that may be real due to low fluid, but it seems I topped that off not long ago. Googling on those codes comes up with lots of hits of Pontiacs/other GMs throwing the same set of codes along with the fuel gauge problem, seems to be related to a problem with a 5V reference circuit that powers such things as the TPS, manifold pressure sensor, fuel tank pressure sensor. Other than the goofy gauge and CEL,car seems to run fine, although at times the tranny kickdown on hitting the throttle seems boggy. I'm thinking a bad grobnd circuit somewhere, but with so many hits on the same set of codes, coincident with the fuel gauge issue, hoping someone else has nuked this one out already. Tried searching on the forums here with no real help, in general, I have had trouble getting good hits on searches on here for many different items.
Chris, Stonington, CT
2001 GP 3.1 85K
