So my car threw a P0300 the other day. I can't decide what to replace first. I've got a list of stuff I can replace, Spark Plugs & Wires, Ignition Coils & ICM, Oxygen Sensors, Fuel Injectors, Exhaust Valves, Catalytic Converter (no point it's brand new), EGR valve, camshaft position sensor, or the worst case scenario my Computer is Defective!!! AH!!!
Symptoms:
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Anyone had this code thrown and where did you start?
