Thread: Are these pretty much toast?
Results 21 to 40 of 46
  1. #21 Re: Are these pretty much toast?
    mine cam right the F off. i mean like real easy. must have been cause i was at Bills house lol
    i will add, if you ever swap your tranny, thats a good time to change the lca's, as the sub frame is on the floor now.
  2. #22 Re: Are these pretty much toast?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Yeah didn't do it then already swapped that haha
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #23 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    How hard is it to change just the bushing though? I don't wanna spend $60 on the LCAs then end up not being able to get mine off and throwing away the new ones in defeat
  4. #24 Re: Are these pretty much toast?
    pretty sure you need a press to get them out and back in.
    new are 42 bucks each, whats the problem? lol new arm, bushings and a new ball joint, you need to take the arm off to change the bushing, so why not just put a whole new arm in there.
    oh get a new set of end links for your sway bar, or plan on getting them, if old, they never come off.
  5. #25 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Sway air and endlinks are band new, the problem is I feel like I'm gonna buy new arms, get my car in the air, go to get the old ones off and not be able to then get stuck with the control arms and have wasted my money
  6. #26 Re: Are these pretty much toast?
    I live here. DirtDog's Avatar
    Jun 2012
    well theres always you can return them. but i almost guarantee you with a little pb blaster and a braker bar they'll come off fine
  7. #27 Re: Are these pretty much toast?
    Quote Originally Posted by asite57 View Post
    why would they not come off? its not that bad really. spray all the nuts down for a few days before you go at it if it makes you feel better.
    like i said, mines a 98 and the nuts all came right off. not even a fight. no pre lubing or nothing. iirc, after they broke free, i took the nuts off by hand.
  8. #28 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    I don't have a pickle fork could I just use a crow bar?
  9. #29 Re: Are these pretty much toast?
    The hardest bolts are ball joint and sway bars end links both can be cut off if you have a sawzall. Those pics are from my mom and dads venture with 220k miles and it came right apart. My car i had to cut off ball joints.
    Jun 2012
    U don't need a pickle fork...if replacing them a hammer or something to bang em out with will work fine. Done it several times
    Sent from my DROID RAZR using Tapatalk 2
  11. #31 Re: Are these pretty much toast?
    believe it or not, at Bills house, he stuck a 4 or 5 foot pipe over the top of the lca, then under the car, then hopped on the bar and whacked the lca with a hammer at the ball joint area. popped right off. like a boss. no fuss, no muss.
  12. #32 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Did you need an alignment afterwards?
  13. #33 Re: Are these pretty much toast?
    your wheel may or may not be off a bit. 50/50 shot. if you need tie rods or anything else now would be a good time, then get it all aligned.
    my wheel was off a bit, but i think that was due more to the sub frame not being exactly where it was when it went back on. the rack bolts to the sub frame, so if the sub frame moves, the wheel will move.
  14. #34 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Why did your subframe move? I already changed the tie rods
  15. #35 Re: Are these pretty much toast?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    u can change it on the car if u have a lift and air hammer u air hammer the old bushing ring out and then use a reg hammer and jack stand and hammer the new bushing in bushings are like 10 bucks at autozone easy to do just remember to lube up the new one before installing
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  16. #36 Re: Are these pretty much toast?
    his subframe was out for a trans swap ^^
  17. #37 Re: Are these pretty much toast?
    Billboost swapped my tranny, so the sub frame had to come off the car. thats when i jumped on the lca's . when it went back on it must have been off to one side a bit.
    you should be ok. but either way bushings or new arms theres a chance of the wheel being off a bit. its a major front end part. if it was last aligned with old parts then you put new parts in, things can change with in the alignment.
  18. #38 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Yeah it's no big deal doing an alignment is easy ill probably Judy sway the arms this is very expensive if I have to have a shop do it
  19. #39 Re: Are these pretty much toast?
    from Bills axle swap how to. http://www.grandprixforums.net/how-r...xle-39805.html
    Bring in a 4-5 foot prybar (I use my steel floor jack handle) from by the front bumper where the wheel well meets it toward the body between the body edge and subframe bolts. Slide it under the axle and over the control arm.
    Pry down. It helps to have a helper. At the same time as the prying, hit the balljoing on the side (not where the grease zerk is, other side ) and after a few hits the ball joint will come free from the knuckle. Move the strut/knuckle behind the ball joint before letting the control arm back up.
    seen this in real life, made it all look easy lol
  20. #40 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Ill give it a shot
  1. Pretty sure the engine is toast :(
    By Slick2500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2012, 01:02 PM
  2. I'd say it's toast
    By jwjones in forum Off Topic Discussion
    Last Post: 01-12-2012, 07:30 AM
  3. Yeah toast!
    By afallucco in forum Off Topic Discussion
    Last Post: 01-15-2011, 08:20 PM
  4. Are my cluthes toast? FU firestone!!!
    By Pepino in forum General Tech Discussion
    Last Post: 05-25-2010, 11:19 AM
  5. 3rd gear toast
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 07:03 AM
