Thread: Are these pretty much toast?
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Are these pretty much toast?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Drivers side
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Passenger side
    I live here. DirtDog's Avatar
    Jun 2012
    Dang that looks nasty. Their easy to replace and over all not to expensive
    Sent from my DROID RAZR using Tapatalk 2
  4. #4 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    They gotta be pressed in if I recall correctly?
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Yes they toast..replace them
    Sent from my SGH-T679 using Tapatalk 2
  6. #6 Re: Are these pretty much toast?
    antioch ill
    i clicked on here hoping to see toast not more racekar parts damn you
  7. #7 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    How do I do that I though control arm bushings have to be pressed in. Can i just pop that bolt out and slid new bushings in?
  8. #8 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Matt ill give you ****ing toast!!!!!!!!
  9. #9 Re: Are these pretty much toast?
    antioch ill
    i like waffles better thanks for the offer tho
    Jun 2012
    You can get a whole new control arm. I got Moog ones for mine for 60 bucks for each side and that includes those new bushings, and new lower ball joints on the control arm. Less of a hassell. Check local auto parts store or advanced auto online and use a discount code. Or rock auto
  11. #11 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Is this the part I need?
    More Information for RAYBESTOS 5651298
  12. #12 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Yeah but changing ball joints are a *****
    Jun 2012
    No. If u buy a new control arm than it comes with it all put together. So all u have to do is take old control arm out and put new on. The new one will have new ball joints riveted on and new bushings
  14. #14 Re: Are these pretty much toast?
    dont bother changing the bushings, just get new lower control arms, your ball joint is shot as well if the one bushing looks that bad.
    dorman lca's cost me 98 bucks shipped to my door for the pair.
    it was the last thing i changed and all the clunking and thuds stopped after i changed them. car rode like new again. well at least it felt better.
    Jul 2012
    California
    Great how-to by dsmuts
    http://www.grandprixforums.net/showthread.php?t=66203
  16. #16 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    I've never done any ball joint/control arm work to these cars before. If I buy a hole new arm do I just unbolt and bolt on? I thought I had to get the ball joint tool (giant arm thing) and undoing the old ball joint is a pain ect?
    Jun 2012
    Exactly. If ya want I can copy some pics and how to info on here for u
  18. #18 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    I read that write up and it seems doable but I know for a face every bolt on my arms are gonna be frozen tight....
    Jun 2012
    Well either way u gotta take the arm off so just soak em in pb blaster or do what I've done a few times and use a torch and heat the bolts off. Either way gets them off
  20. #20 Re: Are these pretty much toast?
    Oct 2011
    Michigan
    Why would I have to remove the arms to change the bushings?
  1. Pretty sure the engine is toast :(
    By Slick2500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2012, 01:02 PM
  2. I'd say it's toast
    By jwjones in forum Off Topic Discussion
    Last Post: 01-12-2012, 07:30 AM
  3. Yeah toast!
    By afallucco in forum Off Topic Discussion
    Last Post: 01-15-2011, 08:20 PM
  4. Are my cluthes toast? FU firestone!!!
    By Pepino in forum General Tech Discussion
    Last Post: 05-25-2010, 11:19 AM
  5. 3rd gear toast
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 07:03 AM
