Yes. I have a check engine light on right now. It happens every winter though. I live in the south; so for the 3 months that it is semi-cold, the check engine light comes on for the coolant. It doesn't leak like crazy, but it does leak very little as time goes on. The code goes off for either the thermostat, coolant reader, or coolant level is low. I know its not the thermostat because my temperature gauge stays at a normal setting, but it might be the coolant reader because I filled the coolant the other day, and the check engine light came on again. I checked it and it was still pretty full. The engine light also comes and goes. It will stay on for like 7 days, and then turn off for 2. It just came back on three days ago again.
As for the engine mounts. The mechanic said that they did need to be replaced due to the feel of the car when he shifted from park to drive.
Thanks for the comments and looking forward to other ones.
Josh
