I've posted about my previous issues here with electrical problems. Those all seem to be gone. My main power and grounds have been upgraded. Battery is perfectly fine. Starts like new now. My problem? The tach and speedometer aren't moving.
My IC lights up when I have the lights on and shows my turn signals so there is power to some things. I did swap the BCM then put my old one back and mess around under the dash so any ideas about this?
Also, a wire from my remote starter pulled out of the awesome electrical tape connection that was used. This wire goes to the tach so I re-attached it where I saw the messy connection of the tach (white wire) connected to a brown wire in front of the DRL box (or whatever the name is for the box before the BCM). *correction - This is for the parking lights and hooked up right. The remote installer used some wrong colored wire here* My fuses all seem to be good except for a missing 20A to my sunroof and under the hood the 30A "Air" one listed on my box has nothing to plug a fuse into for some reason.
