Thread: Tach/Speedometer No Power
Results 1 to 5 of 5
  1. #1 Tach/Speedometer No Power
    Apr 2009
    toledo
    I've posted about my previous issues here with electrical problems. Those all seem to be gone. My main power and grounds have been upgraded. Battery is perfectly fine. Starts like new now. My problem? The tach and speedometer aren't moving.
    My IC lights up when I have the lights on and shows my turn signals so there is power to some things. I did swap the BCM then put my old one back and mess around under the dash so any ideas about this?
    Also, a wire from my remote starter pulled out of the awesome electrical tape connection that was used. This wire goes to the tach so I re-attached it where I saw the messy connection of the tach (white wire) connected to a brown wire in front of the DRL box (or whatever the name is for the box before the BCM). *correction - This is for the parking lights and hooked up right. The remote installer used some wrong colored wire here* My fuses all seem to be good except for a missing 20A to my sunroof and under the hood the 30A "Air" one listed on my box has nothing to plug a fuse into for some reason.
  2. #2 Re: Tach/Speedometer No Power
    What do you drive?
  3. #3 Re: Tach/Speedometer No Power
    Apr 2009
    toledo
    What do you drive?
    Yeah... that might have been important. 2000 GTP. It also seems to bog out after a bit unless I'm on the gas.
  4. #4 Re: Tach/Speedometer No Power
    Apr 2009
    toledo
    No ideas? Nuts.
  5. #5 Re: Tach/Speedometer No Power
    Check out your wiring harness on the passenger side back of the motor
  1. Tach issue
    By mr_gtp in forum General Tech Discussion
    Last Post: 03-24-2013, 10:31 PM
  2. Tach drops to zero
    By ahill261 in forum General Grand Prix Discussion
    Last Post: 10-05-2012, 10:11 PM
  3. Tach never works
    By proguitarjammer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2012, 12:47 AM
  4. tach jumps
    By wilder9032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2010, 06:27 PM
  5. Tach and Tcs light
    By sgtsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2009, 10:44 AM
