Thread: 99 gtp no boost
Results 1 to 13 of 13
  1. #1 99 gtp no boost
    Jan 2013
    florida
    I have a 99 gtp my boost gauge shows no boost hasnt since I got it a month ago any advice tofind outif this is working or not?
  2. #2 Re: 99 gtp no boost
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: 99 gtp no boost
    Sep 2011
    Copperas Cove, TEXAS
    Check ALL vacuum lines, if no probs then unplug the electrical connector on the BCS and see if that works, it worked for me.
    Here is a detail of what I did, STILL don't know why it works, but fvck it!!! I have 7.6# now. http://www.grandprixforums.net/low-b...rns-71622.html
  4. #4 Re: 99 gtp no boost
    Never Never Land
    Does it run any different? Poor fuel mileage? As Tanker said check the vacuum lines. Your boost gauge is fed by the vacuum lines so if you have one that's broke or leaking it won't register boost in the DIC. Also check the BCS as he said too.
    My old 99 would only make ~half boost on the DIC. I swapped BBV, messed with vacuum lines etc until a member here said to check the BCS. What you can do to check that is simply disconnect the vacuum line from it. Solved my half boost, irratic shifting, irratic T/C lockup, as well as terrible fuel economy.
  5. #5 Re: 99 gtp no boost
    Sep 2011
    Yup since I fixed it I get 30MPG Avg on the highway.
  6. #6 Re: 99 gtp no boost
    Never Never Land
    ^^^That. I only managed around 15 in town and like 22 highway. Unplugged the vac line never to touch it again and I got low 20's town, low 30's highway.
  7. #7 Re: 99 gtp no boost
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Check your vac lines with Carb cleaners and also make sure the BBV is working properly.
    If BBV is fine and so are vac lines, block off BB Solenoid.
    The Boss Iceman6669's Avatar
    Jun 2011
    IIRC the DIC boost gauge only shows BBV position. IE when the DIC shows you making full boost your BBV is fully open, regardless of PSI.
    2011 F-150 Yote powered
  9. #9 Re: 99 gtp no boost
    Max Cook
    Guest
    Quote Originally Posted by Iceman6669 View Post
    Are you sure about that? When I was making **** boost (4-5ish lbs) because of a vac leak the guage would only go about halfway. Had nothing to do with my BBV. I thought it went off PSI it just only went up to like 7 or 8.
  10. #10 Re: 99 gtp no boost
    Never Never Land
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    It's ran off the vacuum line that goes under the snout.
    Quote Originally Posted by Max Cook View Post
    Eff you 3 character minimum
  11. #11 Re: 99 gtp no boost
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    hows it do that ?^
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  12. #12 Re: 99 gtp no boost
    Jan 2013
    IL
    Not to be that guy, but check the condition/presence of a belt on your SC. Had the same problem, found out it snapped off a few days earlier. Just saying.
  13. #13 Re: 99 gtp no boost
    Never Never Land
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
