Have you checked the underhood fuses as well? Not sure if there is anything there that would control these 2, but worth a look.
The blower motor could just have a bad connection. Put it on high and then follow the wiring to it under the dash and give it a wiggle. It may spring to life.
Does the rear defroster still work? I've seen bad LED's in those buttons before, so its not out of the realm of possibities that you have 2 units w/ burnt bulbs.
