Thread: climate control center issue
Results 1 to 2 of 2
  1. #1 climate control center issue
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    okay so my issue right now is my blower motor is either bad or isnt engaging because of another issue... my rear defroster light doesnt come on and i have switched out the whole climate control piece that goes under the radio.. now could those issuse be related or no? also i checked fuses there good
  2. #2 Re: climate control center issue
    St. Louis
    Have you checked the underhood fuses as well? Not sure if there is anything there that would control these 2, but worth a look.
    The blower motor could just have a bad connection. Put it on high and then follow the wiring to it under the dash and give it a wiggle. It may spring to life.
    Does the rear defroster still work? I've seen bad LED's in those buttons before, so its not out of the realm of possibities that you have 2 units w/ burnt bulbs.
  1. Climate control issue
    By kingjohn1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2012, 09:25 AM
  2. dual climate control issue
    By bigdawg00 in forum General Tech Discussion
    Last Post: 11-09-2011, 06:37 AM
  3. Climate Control Issue, please help!
    By heathersmanforlife in forum General Tech Discussion
    Last Post: 06-04-2011, 01:10 PM
  4. 2000 GTP Climate Control Issue
    By ubuimme in forum General Tech Discussion
    Last Post: 05-23-2010, 08:04 PM
  5. Climate Control Issue - Help!
    By sb7605 in forum General Tech Discussion
    Last Post: 12-17-2009, 10:50 AM
