Thread: Help! Car won't start without pressing gas
Results 1 to 10 of 10
  1. #1 Help! Car won't start without pressing gas
    Jul 2012
    Rochester, NY
    Hello everyone, my 04' Grand Prix has trouble starting sometimes. Usually I have to press the gas in order to get the engine to start. After that it runs like a champ! But if the car is sitting over night it starts normal (without pressing gas) But it's very annoying and I know it's not supposed to do that. I'd like to know some of the possible reasons it may be doing that. I also have a engine light on for a bad thermostat and was told it may be related but I'm not sure how. Any help with understanding my starting problem would be great help, Thank you.
  2. #2 Re: Help! Car won't start without pressing gas
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Mine used to have that same problem. Clean your MAF and throttle body and it'll start without so much as a hiccup.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  3. #3 Re: Help! Car won't start without pressing gas
    Yep clean your tb and all will be well.
  4. #4 Re: Help! Car won't start without pressing gas
    Jul 2012
    Rochester, NY
    Okay thanks how should I clean my/what should I use to clean the MAF and throttle body?
  5. #5 Re: Help! Car won't start without pressing gas
    brake clean on tb. Electrial parts cleaner or maf cleaner on the maf sensor.
  6. #6 Re: Help! Car won't start without pressing gas
    Jul 2012
    Rochester, NY
    Okay thank you, I just want my car to start normal again
  7. #7 Re: Help! Car won't start without pressing gas
    Jul 2012
    Rochester, NY
    For the throttle body, should I just clean the boar or should I clean whatever is in the electronic control modual attached to it?
  8. #8 Re: Help! Car won't start without pressing gas
    Unbolt the whole thing, should be like 3-4 bolts. You want to clean the throttle body blade and the whole bore, it will be all nasty and black.
    Minnesota
    This.
    2015 Evo MR
  10. #10 Re: Help! Car won't start without pressing gas
    Pennsylvania, USA
    Don't be afraid if a little coolant comes out, it won't be much if any, but there is a coolant passage that goes through the throttle body. Check the gasket while you have it off.
  1. car won't start
    By nina in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2012, 06:36 AM
  2. my car wont shift from park without pressing relese button
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-12-2012, 12:49 AM
  3. Just became my most pressing issue!!
    By spider4 in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2011, 06:43 PM
  4. *SOLVED* Starts fine - will not idle or run by pressing pedal
    By cptnjarhead in forum General Tech Discussion
    Last Post: 10-10-2011, 06:58 AM
  5. Pressing the pulley off
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:01 PM
