Thread: How does radiator cap work?
Results 1 to 4 of 4
  1. #1 Re: How does radiator cap work?
    Look at the bottom of your radiator cap. There are two seals. One that seals at the top neck and one that seals at the bottom of the filler neck. As the fluid heats up it expands. It eventually over powers the primary spring in the radiator cap.
    The bottom seal is broken as the pressure exceeds the spring force of the cap and the cap rises. Fluid then enters the overflow tank until enough pressure is relieved to allow the spring to force the bottom seal back into place.
    You'll also find on the bottom center of the cap that there's a brass or stainless circle plate. That circle plate actually creates a one way check valve. When the engine cools back down the coolant shrinks in volume. As that happens the pressure in the coolant system becomes a vacuum pulling down on the bottom circle plate and thus opens the check valve.
    Once the valve opens the fluid is drawn in through the tube that leads to the bottom of the reservoir and refills the system. The system is actually self burping in that it evacuates air on each temperature cycle. Air is pumped out when the system gets hot and fluid is then drawn in when it cools.
    Does that help?
  2. #2 Re: How does radiator cap work?
    Oct 2012
    USA
    Does that help?
    Thanks! That does help. It confirms that my understanding of how radiator work is correct. Then, my confusion still persist. When cold, I can squeeze the upper or lower radiator hose and saw coolant being pushed into reservoir. How does the fluid go there? The fluid can only go out of radiator to reservoir when there is big pressure to push against the spring in the cap. I don't think the light squeeze create enough pressure to push up the spring.
  1. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  2. Remote start - Used to work great now after some messing around it does not work.
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2012, 11:24 AM
  3. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  4. cant get radiator fans to work
    By rocknkroll in forum General Tech Discussion
    Last Post: 05-05-2011, 07:51 AM
  5. Radiator fan on 96 GP won't work
    By Boatman in forum General Tech Discussion
    Last Post: 05-17-2008, 07:43 AM
