Thread: Start-Up Problems
Results 1 to 9 of 9
  1. #1 Re: Start-Up Problems
    Oklahoma
    Moved to the Tech Lounge.
    Well the easiest way to start troubleshooting this is to know what we can eliminate as culprits.
    1. Lets make sure fuel pressure is good. Does you or your cousin have a way to measure fuel pressure off the schrader valve? I would check that, and get that out of the way and see if we can eliminate a fueling issue caused by a possible issue with the fuel pressure regulator or something like that.
    2. The other thing that comes to mind is a possible issue with the MAF sensor. So I would try and unplug that and see if the car starts up any easier. I dont 'think' that is the issue, but lets rule it out just the same.
    Lets start there. If you will take the advice given to you in these forums (not just mine) Im pretty sure we can get this narrowed down for you. It will take time though and probably wont happen over night but everyone in this community will do all they can to help you.
  2. #2 Re: Start-Up Problems
    Barksdale AFB, LA
    Apparently this is a common problem with the drive by wire stuff in the Series III engines:
    http://www.grandprixforums.net/f17/2...will-5168.html
    2009 Subaru Impreza WRX STI
  1. Car won't start
    By 03GTPFour in forum General Tech Discussion
    Last Post: 08-04-2009, 03:03 AM
  2. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
  3. RPM surge at start?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-07-2008, 06:24 PM
  4. Let me start over
    By vermsta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2008, 06:02 PM
  5. Wouldn't Start
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 09:27 PM
