Why are the heads off? I would imagine you could run the heavier springs, but I do not know if the stock cam shaft is hardened enough to withstand the extra force. If you do change the springs you should change the chain the same time. The old chain will fail under the extra force. Why do you want to change the springs now? You'll need to take everything apart again to do the cam I would just wait till then.
