Thread: EGR Delete Benefits/Discussion
Results 1 to 13 of 13
  1. #1
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by BLACKEDOUTGTP View Post
    so what kind of hp increse are we talkin bout?
    So small that no one that I know of has been able to put a number on it. Just unplug the elecrical connection and see how much different it feels. I have a plate that just bolts under the valve itself. One day I swapped the plate out a few times and noticed no diffence.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    Port Hope Ont,Canada
    This is were you block off
    for the EGR
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
    PA
    If you run less AFR, while being less efficient.....it uses less fuel.
    Reptile,
    I don't understand the above quote from you. If you are saying with the EGR, it is less efficient, it should use more fuel. But you say less efficient means it uses less fuel? I am confused.
    In my experience, I left mine on my car since I never had a reason to take it off. But I developed a crack in one of the EGR tubes, and it created a massive vacuum leak. So instead of replacing the tube, I just removed the EGR valve. I used my PT and returned my VE, MAF and timing, and I did not notice any drop in fuel efficiency. Again, this is my experience.
    2001 GSE
  1. what the heck does "FWI, PEM, AND EGR DELETE" MEAN?
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 01-08-2008, 08:31 PM
