Thread: knock sensor?
Results 1 to 18 of 18
Threaded View
gotboost3 knock sensor? 10-15-2008, 10:58 PM
gotboost3 Re: knock sensor? 10-15-2008, 11:04 PM
Guest Re: knock sensor? 10-16-2008, 12:40 PM
gotboost3 Re: knock sensor? 10-16-2008, 07:32 PM
Guest Re: knock sensor? 10-15-2008, 11:05 PM
gotboost3 Re: knock sensor? 10-16-2008, 07:32 AM
SyntheticShield Re: knock sensor? 10-16-2008, 09:37 AM
Guest Re: knock sensor? 10-16-2008, 07:39 PM
gotboost3 Re: knock sensor? 10-16-2008, 08:02 PM
Guest Re: knock sensor? 10-16-2008, 09:14 PM
02BlueGT Re: knock sensor? 10-16-2008, 11:07 PM
gotboost3 Re: knock sensor? 10-19-2008, 03:56 PM
gotboost3 Re: knock sensor? 10-19-2008, 06:07 PM
Blown97 Re: knock sensor? 10-19-2008, 06:47 PM
Guest Re: knock sensor? 10-19-2008, 07:10 PM
Blown97 Re: knock sensor? 10-19-2008, 07:19 PM
gotboost3 Re: knock sensor? 10-19-2008, 09:33 PM
Blown97 Re: knock sensor? 10-20-2008, 12:19 AM
  1. #16 Re: knock sensor?
    Feb 2008
    It's all good, at least he's running and running well.
    I would however like to know when you would need to do this. I know that the higher the compression or more boost you would need a stronger spark using stronger ignition components. Is getting a stronger spark by gaping the spark plugs to a smaller gap a way to achieve this without using stronger ignition components?
  1. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  2. Knock Sensor
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:51 PM
  3. Very informative - mostly on Knock
    By 04CompG in forum General Tech Discussion
    Last Post: 09-06-2008, 01:20 AM
  4. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
