Thread: Can't remove plastic "nut" holding spare tire in well.
Results 1 to 7 of 7
  1. #1 Can't remove plastic "nut" holding spare tire in well.
    SE Level Member clagrow's Avatar
    Illinois
    This thing is driving me crazy! I'm trying to remove the "nut" holding the spare tire well cover in place but the bolt is spinning underneath and it just keep spinning...I've tried heating it up with a heat gun hoping that the heat would expand the metal enough for it to unscrew and I've tried banging on it and even pryin up on it while turn in it. Any ideas? Thanks
    2003 Grand Prix GT
  2. #2 Re: Can't remove plastic "nut" holding spare tire in well.
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    If the plastic is spinning on the bolt, I'd probably try and pull/break the plastic nut off and use a vice grip to unscrew it the rest of the way, although once the nut is off you can get everything out from underneath anyway. Then I'd find the whole bolt with the plastic nut at a junk yard to replace it.
    You have a flat that you need to get in there?
  3. #3 Re: Can't remove plastic "nut" holding spare tire in well.
    Nov 2012
    Madison
    before you do that^^^
    try with the grips on 1 side and leverage to one side/turning at the same time,trying to pressure the metal insert nut to turn
    prolly would take a while.
    otherwise yeah like b#min said just have at the plastic until the insert is there
    great time of year for the simple things to go wrong
  4. #4 Re: Can't remove plastic "nut" holding spare tire in well.
    Illinois
    Thanks guys, I've tried the leverage thing but I figured I try asking before just breaking it apart...guess that sounds like the plan.
    2003 Grand Prix GT
  5. #5 Re: Can't remove plastic "nut" holding spare tire in well.
    Donating Users Slappyn's Avatar
    Dec 2012
    Goldsboro, NC
    Can you try a pair of needle nose lock pliers to hold the threads underneath? If you could rig up an impact gun what would probably work as well. Drill if you have to and or try the other sugestions.
  6. #6 Re: Can't remove plastic "nut" holding spare tire in well.
    Indianapolis
    Plastic melts
  7. #7 Re: Can't remove plastic "nut" holding spare tire in well.
    id cut that plastic off so it fits through the hole in the floor board, then go to town on it, junk yard for a new top nut and shaft if needed.
    my rod is only held in by a hook under the jack. so if you get the floor off, lift the tire and jack off the floor some, and slide the hook to one side to release it, and then you can work on the ground at least. cut the rod, what ever.
  1. how to remove "Service Tire Monitor System"
    By 04GT in forum 04+ Specifics
    Last Post: 12-20-2011, 10:13 AM
  2. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. What spare tire (doughnut) to use with 12" brake upgrade?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2009, 10:45 PM
