Thread: Stall/No start problem
Results 1 to 16 of 16
Orinackra Stall/No start problem 01-10-2013, 11:11 AM
BillBoost37 Re: Stall/No start problem 01-10-2013, 11:15 AM
blueguy Re: Stall/No start problem 01-10-2013, 11:15 AM
blueguy Re: Stall/No start problem 01-10-2013, 11:17 AM
BillBoost37 Re: Stall/No start problem 01-10-2013, 11:19 AM
Orinackra Re: Stall/No start problem 01-10-2013, 11:33 AM
BillBoost37 Re: Stall/No start problem 01-10-2013, 11:35 AM
Orinackra Re: Stall/No start problem 01-10-2013, 11:43 AM
Orinackra Re: Stall/No start problem 01-10-2013, 04:57 PM
JLiss Re: Stall/No start problem 01-10-2013, 05:46 PM
BillBoost37 Re: Stall/No start problem 01-11-2013, 08:20 AM
Orinackra Re: Stall/No start problem 01-11-2013, 05:00 PM
JLiss Re: Stall/No start problem 01-11-2013, 05:55 PM
Orinackra Re: Stall/No start problem 01-12-2013, 08:45 AM
JLiss Re: Stall/No start problem 01-14-2013, 10:23 AM
  1. #1 Stall/No start problem
    Oct 2012
    Pittsburgh
    Hey guys, looking for some input. 98 GTP
    Car stalled, wouldn't start back up. Would just crank and crank. Got the car towed home, had the battery and alt tested, both good. Car started after sitting for about four hours. Took it for a ride, about 2 miles, all seemed well, but when I pulled in the driveway, and left it running while I cleaned up my tools, it stalled again and wouldn't start back up. I did notice that it drove just fine, but when I was coasting down a steep hill the rpms bobbed between 1000ish and maybe 700ish. Idled perfectly normal. Started up just fine this morning, but I haven't driven it. I have a P0102 for MAF low input, but I've had this code for about a month now, I was just putting it off replacing the MAF.
    I think I have it narrowed down to the following:
    -bad MAF
    -Crank Position Sensor
    -Fuel Filter
    -Fuel Pump
    Anything else I could possibly check? Also, if I start it with the MAF disconnected, will I be able to drive it? I'm trying to figure out why it would start with the MAF unplugged, but not start with a bad MAF plugged in.. if that makes any sense. I'd like to eliminate that as a possible reason for the no start.
    And as far as the CKPS goes, I was reading that a test for that is spark to the coils. I definitely have spark at the coils. I haven't been able to recreate the stalling condition to notice if the RPMs drop to zero, but other than the spark, it sounds like a lot of other threads that suggest replacing the crank sensor.
    I'm going to have to wait until next weekend to replace the MAF, but I might do the CKPS and fuel filter now to see. Any other insight would be appreciated.
  2. #2 Re: Stall/No start problem
    Unplug the maf and drive it. If you don't stall again, you know the issue.
  3. #3 Re: Stall/No start problem
    Easy test here, unplug the MAF and start the car.
    If it starts up and runs fine, then there you go...you found the issue.
    Most of the time when the crank sensor goes, your tach with run itself all over the place and end up pegging out at 0, as if the car is off. At least that was my experience with it.
    You can get a cheap, used MAF from www.moradpartscompany.com...factory one as well.
  4. #4 Re: Stall/No start problem
    In before the Blue!
  5. #5 Re: Stall/No start problem
    Bill beat me to it.
  6. #6 Re: Stall/No start problem
    As usual!
    Op.. Please let us know if the maf is the issue. It's a very common cause to the symptoms you have.
  7. #7 Re: Stall/No start problem
    Oct 2012
    Pittsburgh
    cool, thanks guys. MAF is unplugged now, it starts, runs a little rough, but I guess that's to be expected. I'm gonna take it for a drive in a little bit. I won't have the new MAF until next week, but I'll report back.
    I'm just confused why it would start with the MAF unplugged, but not start plugged in.
  8. #8 Re: Stall/No start problem
    If your maf is bad and telling the pcm it sees no airflow during crank..it won't give you fuel.
  9. #9 Re: Stall/No start problem
    Oct 2012
    Pittsburgh
    That makes sense.
  10. #10 Re: Stall/No start problem
    Oct 2012
    Pittsburgh
    Ok, so I went and got a new MAF. Installed. Started up. Took it around the block, no problems. Went in the garage for a minute, and it stalled. Started back up, ran for about a minute, then it started to sputter, and stalled. Now it won't start at all. Although, now I'm actually not sure it's getting spark. I did the screwdriver to the number 1 plug while cranking, and nothing. Crank sensor? Oh, and no check engine light now. I don't want to rule out a fuel problem, cause it's getting fuel to the rail (not sure on the pressure).
  11. #11 Re: Stall/No start problem
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    fuel pressure test your fuel system.
    2009 mazdaspeed3-self tuned Cobb AP,Custom water to air IC,3" intake, 3" DP' 3" exhaust, Forge Wg actuator, Ricer mods, Cobb suspension
    2004 mazda 3-custom big turbo kit, blew up 4x went back stock (Details/pics ask)
    1997 GTP S/C 3.4 pulley, intake, all i know so far.
  12. #12 Re: Stall/No start problem
    Once it stalls, your pressure may bleed off slow. Older pumps are common for that.
    Double check for spark. It might be crank sensor. BTW ... we suggested unplugging...not buying. That way if it ran decent, the suggestion would have been that the maf was bad. However since it stalled again, likely the maf was ok.
  13. #13 Re: Stall/No start problem
    Oct 2012
    Pittsburgh
    I wasn't too worried about the MAF. I got one from a junkyard for $25. And I had some sort of problem with the MAF regardless, due to the P0102.
    Well, I went outside today, tried to start it, nothing. Put the new crank sensor in.... fired right up. I haven't driven it yet though. I'll probably do that tomorrow. Work + this = tired me.
    PS. Mother Nature? More like Mother F-er. Rained all day, and as soon as I put the last lugnut back on, the sun came out. Sonofa--
  14. #14 Re: Stall/No start problem
    Dec 2012
    Aurora, IL
    sweet now make a donation to the website for the info here! 5bux 10bux whatever you can spare.
  15. #15 Re: Stall/No start problem
    Oct 2012
    Pittsburgh
    Muaww. Test drive success. Hopefully this is it. It's been running for a half hour with no ill effects. Thanks for all the help gents. Jliss, I think I can swing that. Hell, that's a bargain compared to having to take the car to a shop.
  16. #16 Re: Stall/No start problem
    Dec 2012
    Aurora, IL
    good forums will save you tons of time, headache's and money, small donations keep it coming!
  1. The Common Stall Start Problem 3800 N/A Series II
    By 94GrandPrixSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2012, 09:08 PM
  2. Stall at Start
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 04:05 AM
  3. erratic idle, stall, one no start... NO CODES!! HELP
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2010, 10:06 AM
  4. start; stall. replaced everything. it's baffling.
    By jessinator in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 04:52 PM
  5. Start and Stall
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 06:35 AM
