Thread: Brakes are frozen
Results 1 to 14 of 14
  1. #1 Brakes are frozen
    Romulus, MI
    My parking brake is frozen on an i cant get it off an also i have a tick on the top of the engine an dont know what it is, i own a 2004 grand prix gt2
  2. #2 Re: Brakes are frozen
    SE Level Member Lowdown112's Avatar
    Dec 2012
    Louisville
    I dont know what to do about the brake. But as for the tick its probably your valves needing adjusted.
  3. #3 Re: Brakes are frozen
    Nobody adjust the valves. Its more than likey a lifter tick or really loud injectors just ticking away like any 3800.
    If the parking brake it frozen, pour some water on it to un-freeze it?
  4. #4 Re: Brakes are frozen
    Frozen like water frozen or rust frozen?
  5. #5 Re: Brakes are frozen
    May 2012
    Cedar Rapids, Iowa
    this kinda happens to mine, try putting your foot behind it and pulling it towards you. it usually loosens it up
  6. #6 Re: Brakes are frozen
    Romulus, MI
    no as in like its stuck on an cant get it to relase
  7. #7 Re: Brakes are frozen
    Have you used it before without problems?
  8. #8 Re: Brakes are frozen
    but what is stuck, the e bake lever your pushing, or the e brakes them self?
  9. #9 Re: Brakes are frozen
    Romulus, MI
    yes iv used it before i went to take it off one day an it stayed on even after the the pedal was released
  10. #10 Re: Brakes are frozen
    I live here. DirtDog's Avatar
    Jun 2012
    take some wd-40 and spray it on the mechanical e-brake components on the rear calipers...they could be frozen up there.
  11. #11 Re: Brakes are frozen
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by marines542 View Post
    Or use PB Blaster, that is a lot stronger than WD40.
    1997 Red GTP 182000 miles stock
  12. #12 Re: Brakes are frozen
    Jun 2012
    also the mechanical brake line that runs from the parking brake it runs into a line similar to the brake lines on bicycles. well that line can rust inside of the shield that is supposed to keep it from rusting. and that can cause it to lock up. it did it on my 91 chevy and i just went to a junk yard and got a different line and swapped them and that fixed it. i dont know on the GP's if the line that runs to the brakes is exposed on the bottom of car like it is on older cars and trucks or not
  13. #13 Re: Brakes are frozen
    Since you would have the ebrake built into the caliper, check the cable movement at the caliper. Figure out if it's the caliper or the cable and go from there. New cables are pretty cheap from Rockauto and not bad to replace.
  14. #14 Re: Brakes are frozen
    Romulus, MI
    ok thank you all for your help, im gonna go try all your advices.. i appreciate all of the help
  1. frozen boost flex pipe
    By blakgtp in forum General Tech Discussion
    Last Post: 09-25-2012, 08:51 PM
  2. frozen boost intetcooler kit
    By mskram1 in forum General Grand Prix Discussion
    Last Post: 01-08-2012, 07:33 PM
  3. frozen boost fmhe 118 or 100
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:47 PM
  4. Frozen Gas filter
    By Lion29GTP in forum General Tech Discussion
    Last Post: 04-07-2009, 09:52 AM
  5. From the Frozen Tundra
    By highlife70 in forum Introductions/Noob Questions
    Last Post: 01-08-2009, 11:03 PM
